Ok just got a new fifth wheel last month. Got a canyon trail 33 ft. Measures 40 ft from end to end. Wonder how they get 33 ft. Weighs 14k full loaded. We want to gomthru the mountains with 6% grades.
We are considering a new f350 6.7 diesel but what would be the best rear end for this load and still get good fuel mileage?
I wonder if the lack of response here is because folks are not sure of the answer. I know I have no idea. I wonder if you might try posting this question on the 6.7 forum and see what those folks have to say. Some of them may have experiences similar to what you anticipate and could offer some guidance.
I hate to see a question just left hanging as it gives the impression no one is interested, which is not the case.
So I'm thinking that if fuel mileage is your starting point, then you need to get the highest tow rating with the lowest number gear. If you weigh your trailer and truck and the 16,700 will pull it, that's your best choice.
But do you need 4x4?
What will be your final totals when you are loaded and pulling out of the driveway?
And if you think like allot of folks, you need about 25% to spare on you GVWR, just for good luck and to save wear and tear on the tow vehicle.
I don't know how much fuel mileage you lose with dual rear wheels, but I bet it's enough to get your attention.
Good luck with this thread, I hope we get some more input, as I am also trying to match the trailer I want with the proper tow vehicle.
Man, tough issue if it is mileage as you have to decide how much mountain time versus flat or relatively flat and in the end, I bet there is darn little difference between the two ratios, all other things being equal.
This was wet weight (went over certified scales, unhooked and weighed just the truck to get this weight) and we would be in the mountains probably 6 times a year. Just don't want to kill the engine with overheating issues.
What does it measure not counting the 5th wheel portion?
Have a Raptor 36 ft toy hauler that's about the same weight. I initially had a F250 6.2 with airbags and a SCT tuner. Seemed to do ok. We pull almost all flatland. Traded the truck for a F350 6.7 with the 3:55 based on conversations with my service manager. World of difference. The 3:55 seems to offer decent all around fuel mileage and the pulling isn't even comparable. Only regret is not getting the diesel to begin with.
Ok just got a new fifth wheel last month. Got a canyon trail 33 ft. Measures 40 ft from end to end. Wonder how they get 33 ft?
Usually the rig is measured from the pin to the back bumper. Mines a 32' toy hauler on the tag but really measures 34' total. How you get 7 extra ft seems odd. Are you sure the tag or model # is only 33'?
To the others points... You can get great towing but poorer mileage or visa versa. No free lunch here.
My 6.0 isn't nearly as powerful but the 3.73 gear ratio pulls just fine with my 15,500 gvw. I would think the 3.31 or 3.55 would both do just fine.
You're right, normally the overall is about two more than stated, but then hey, you got to remember this an RV. Nothing has to make sense!!
