Axle codes
Old Sep 17, 2013 | 08:33 PM
Mustangking1's Avatar
Mustangking1
Axle codes
Hello,
My rear axle code on my 1978 ford f250 2wd is a 22A
But I can't seem to find in any of the tag decoders a 22A
Can someone help me?
Old Sep 17, 2013 | 08:45 PM
march's Avatar
march
22 - Dana 61 5300# capacity 3.07 gear ratio
A Adjustable steering column with power steering.
Old Sep 17, 2013 | 08:48 PM
Mustangking1
Oh, ok. I got it now.
Thanks!
Old Sep 17, 2013 | 10:32 PM
1Asterisk's Avatar
1Asterisk
The axle code on my 77 F100 vin plate is A9H. I don't find it, or any variation listed in the Service Manual ID Codes section. Could anyone advise it's meaning? Thanks.
Old Sep 18, 2013 | 08:19 PM
march's Avatar
march
Unless it's really H9A I don't have a guess.
Old Sep 19, 2013 | 08:22 PM
1Asterisk's Avatar
1Asterisk
It is clearly 'A9H' under 'Axle Code' on the right side of the VIN Plate. On the rear axle, attached to the left side (looking forward) differential housing cover there is a metal tag stamped with the following:
3 07 07TA-B3F
751 400-1 MEX
If anybody can shed some light on what axle I have, I'd appreciate it. I hope it's not an illegal
Old Sep 19, 2013 | 08:39 PM
78 & 87 Super Cab's Avatar
78 & 87 Super Cab
On a 4x4, I thought the 2 digit number was the rear diff,and the letter code was the front diff
Old Sep 19, 2013 | 09:03 PM
dlburch's Avatar
dlburch
most likely D7TA...
https://www.ford-trucks.com/forums/9...ml#post8545363
Old Sep 19, 2013 | 09:23 PM
1Asterisk's Avatar
1Asterisk
According to my 77 service manual:
"A letter and a number, or two numbers under AXLE identify the rear axle ratio (when required, a letter is also stamped behind the rear axle code to identify the front axle capacity)."
Using this explanation, my axle code 'A9H', the 'H' would ID the front axle capacity and the 'A9' should identify the rear axle ratio. But I don't find the 'A9' ID code listed with all the others in the service manual.
Old Sep 19, 2013 | 09:28 PM
1Asterisk's Avatar
1Asterisk
Originally Posted by dlburch
I think you are correct. Does this indicate a Dana axle, and were they factory installed on F100's of 77 vintage?
1972RedNeck
May 30, 2012 11:33 PM
AndyKotelmach
Sep 17, 2010 09:23 AM
ErrorS
29
Aug 1, 2007 01:09 AM
1ford1
Sep 10, 2006 05:42 PM
Screamin T/A
19
Nov 3, 2003 10:11 PM
