Hi i was wondering where can I find the axle codes for my truck. I have the vin#, but the only other number i can see on the sticker are F1032, and directly below that is T0679. Where else can I find these codes?
I have a 9" rear? I have an F-250. I know I have a Dana 60 rear, but on the front axle it is hard to make out, plus I would like to know the ratio. thanks for the info though.
i dont think there is an axle code on the door jam sticker. there is the vin number, the gvwr for each axle, the tire sizes, and then those other two number that i gave previously.
hey mattsbox? how do you know that it is a dana 44 with a 60 housing etc? Also where in the engine compartment is this tag located? Lastly, I don't know whether this is going to help or not, but my cousin has a 1977.5 F-250, and his front shocks have a mount at the bottom that a bolt goes through, and a mount at the top that has a bolt that you just thread a nut on. My truck has a "bolt" on both ends that you have to just thread a nut (plus bushing etc) on. Thanks
There is also a metal tag in the engine compartment, with the hood open, look straight back to the top of the firewall, there should be a complete VIN rating plate right there. Its held in place by a rivet. It should be there.
It came with a sticker in the door jam, not on the door. This had paint, axle, interior, etc codes on it. It is usually just below the striker bolt.
Jimmy
Haha I can see I have quite a dilema on my hands now. Ok, I looked on the sticker on te door jam and it had my vin, those two other numbers, and the total gvwr as 7400LB, the front is 4500LB, and the back is 4610LB. The actually on the door plate is of no use since it is not an original door. the engine compartment tag is no where to be found. Another bit of info is that I cant tell what axle it is just by looking at the number on the lower right of the axle because this is covered by the u-bolt mounts for the front leaf springs. this along with the weird shocks i stated previously. At this point i just want to know what axle i have forget about the ratio! If you need more info just by looking at it i can help you experts out. Thanks again i hope to get this figured out soon.
not that I'm doubting you matt but a 4500# dana 44? Also does the 44HD have the same pumpkin as a 60? Lastly if I were to buy new locking hubs for this axle would I buy 44's or 60's? thanks
I have a 75 F250 w 44 up front and 60 in the rear. If you look at the front of the pumpkin, the lower webbing on the pass side you should see the number for the axle. Mine says 44 6EF (no clue what the other code is). I also just converted mine from full time to part time, I used warn premium hubs. I'm curious to what was said about the axle being a 60 with 44 ring and pinion. If you get more info please let me know.
