Rear axle ID
Old Sep 4, 2006 | 09:39 AM
1ford1's Avatar
1ford1
Rear axle ID
Can anyone tell me the axle code for a 76 F100 with H7J, and a 79 with a code of 06J? I found the codes for the 78 -79 ID plates but not for the "J". The are original trucks so the tags are actual. The J is for the front axle but both trucks are 2WD's. Is the J for the 2WD?
Old Sep 4, 2006 | 11:32 AM
LxMan1's Avatar
LxMan1
The J = power steering
06 = 2.75 2900lb open rearend
H7 = is possibly a 3.25LS, but I'm not sure on this one.
Old Sep 4, 2006 | 02:48 PM
Mil1ion's Avatar
Mil1ion
Ford doesn't seem put the fornt axle code on any Rating plate.
They only need to out the rear axle because if it is a 4x4, a automotive educated person knows that it has to be the same or marginally different ratio for the front
ie:
3.54 Rear / 3.54 Front
4.11 Rear / 4.10 Front
As Jimmy stated. the J stands for power steering with a NON-Tilt column
But if the truck had Power steering and a Tilt Column that code is X
H7 is a 3.00:1 ratio
Scroll to near the bottom of this page of mine.
http://www.clubfte.com/users/mil1ion...ruckCodes.html
Old Sep 4, 2006 | 04:03 PM
1ford1's Avatar
1ford1
Thanks for the replies. I got under the truck and got the gunk off enough to read the tag. The H7 has the 3L25 tag. I have several of these trucks one being a 78 F150 with an axle code of 11J. I cant find an 11 on the web page and the tag is missing off of the rear. Is there a sight that gives the 73-77 id codes?
Old Sep 4, 2006 | 04:15 PM
Mil1ion's Avatar
Mil1ion
I have all the codes you could ever need right here in my books.
The H7 does not show up listed in a book on the 76.
Perhaps Ford installed it in a late 76.
What is the Vin# on that truck.
It is however listed in the 79-80 Model year for Vans as a 3.00:1
There is already a thread on the Code 11 axle going on right now.
Old Sep 10, 2006 | 05:42 PM
F250TRKS1's Avatar
F250TRKS1
i have a 1985 f250 with a axle code of b3 does anyone no what axle this is
