Sponsored by: Real Truck
1999 F250 AC Problems
Old Sep 16, 2013 | 04:28 PM
beetlebob's Avatar
beetlebob
I have a 1999 F250 7.3 Diesel and my AC isn't working properly. On Max AC as you're driving it would be ok and then it would be warm and then cold and then warm and then cold and so on. I've noticed that the clutch stays engaged as well. I've never seen it disengage. The freon is at the level it needs to be. Then just a few days ago, if you have it on Max and High the air disappears from the vents and you hear a noise somewhere in the dash on the passenger side. I think something might have come off?? Does anyone know what's wrong with my AC with it going from cold to warm constantly? I heard that maybe clutch has too big of a gap?? I have almost 200,000 miles on it.
Old Sep 16, 2013 | 04:37 PM
BigOl04's Avatar
BigOl04
check your ac hub/clutch gap with a feeler gauge.. there is a write up in the search tab on how to do this.. thats what it sounds like to me.. also,, check the clutch on your cooling fan and make sure that it is working properly.. behind the glove box is where all the wiring and vacume lines run for the ac/heat.. lower the glove box and look and see if anything has come lose and or has a vacume leak..
Old Sep 16, 2013 | 05:48 PM
redford's Avatar
redford
FTE Leadership Emeritus
Try this:
Old Sep 16, 2013 | 07:21 PM
projectSHO89's Avatar
projectSHO89
https://www.ford-trucks.com/forums/7...xpedition.html
Old Sep 17, 2013 | 12:40 PM
serratorichard's Avatar
serratorichard
you might want to check your diverter door motor might be going out or loosing its adjustment. thats the trap door motor that opens the direction of air flow from ur heat or cold. just an idea
Old Sep 17, 2013 | 04:25 PM
beetlebob's Avatar
beetlebob
Is that in the dash as well on the passenger side?
Old Sep 17, 2013 | 04:34 PM
BigOl04's Avatar
BigOl04
Yes it is.. behind the blove box area.. Its all back there. pull the door and start tinkering and checking it all out
meier63
Jul 1, 2019 09:53 PM
dpslusser
Jun 11, 2013 12:39 PM
TNT
Apr 21, 2013 09:51 PM
XBAJBUSX
21
May 27, 2010 07:08 AM
haulingboat
Aug 24, 2007 09:06 PM
