Possible AC issue
Old Jun 29, 2019 | 01:47 PM
meier63's Avatar
meier63
Possible AC issue
So my 99 f350 has a slow ac leak.... 1 charge in may/june will get me through the hot summer months. Been this way for about 10 years now. This year is a little different. Temps went from 70ish to over 90 for the last few days prompting me to want my ac. So as normal, added refrigerant, and ice cold air returned. Only abnormal thing in this whole process is that I noticed the ac clutch isn't cycling as it normally does. It's blowing snowballs but clutch stays engaged constant. Could it be a cycling switch issue, or given the temps and high humidity, could this be normal?
Old Jun 29, 2019 | 03:28 PM
FordTruckNoob's Avatar
FordTruckNoob
It is supposed to stay engaged constantly.
Old Jun 30, 2019 | 02:09 PM
'88 E-350's Avatar
'88 E-350
A clutch that cycles is usually because the system is under charged. Overcharged or the evaporator getting too cold will also make the clutch cycle.
Old Jul 1, 2019 | 09:53 PM
kbeefy's Avatar
kbeefy
You need to see your pressures to tell what is really happening. You could be low on freon and high side hovering at 150# because thats all the compressor can do with the available refrigerant, or you could have a bad sensor and pushing 500# when hot.
mizzleman
Jul 13, 2015 04:07 PM
Fulthrotl
Jul 26, 2013 12:29 AM
VA250SD
May 12, 2012 11:58 AM
tj90
1997 - 2003 F150
Aug 14, 2007 11:56 PM
eric777
May 16, 2007 03:20 PM
