Weird ac problem
Old May 25, 2010 | 04:03 PM
XBAJBUSX's Avatar
XBAJBUSX
Weird ac problem
I got 95 ford f250 diesel 5 spd today I took my truck after lunch too work I started the truck put the ac on and I drove to work about 10 min I get to work so I had few minutes I stay in the truck with ac on . After about 4 min the ac start getting weaker and weaker and start blowing warm air so I had to go back to work . After work I came out start the truck turn the ac on it was blowing warm so with the ac on I started driving home after about 2 min off driving the ac got cold again . What is the problem is about 85f out today help me out
Old May 25, 2010 | 04:12 PM
chicagodragon's Avatar
chicagodragon
it could be a number of things. a weak vacuum pump would make the blend doors not work properly. a low charge would require more air flow over the condenser and higher compressor speed. 85f is not hot enough to cause problems.
Old May 25, 2010 | 04:35 PM
Action4478's Avatar
Action4478
A few WAGS
You need to take a look at the compressor clutch when it is getting warm. If not engaging , may need to remove the washer from behind the clutch & put a thinner one in ..(air Gap) may be to large. The condenser may be clogged with dirt . May be low on refrigerant also...
I also agree on the vac pump may not be closing the blend door..Sometimes a pen or pencil will fall from the glove box and bind things up...
Old May 25, 2010 | 04:39 PM
bearhugger's Avatar
bearhugger
Also check fan clutch.
Old May 25, 2010 | 06:55 PM
XBAJBUSX's Avatar
XBAJBUSX
How much pounds off freon should be in the system I'm getting high reading over 100
Old May 25, 2010 | 07:00 PM
chicagodragon
With it running?
Old May 25, 2010 | 07:05 PM
XBAJBUSX's Avatar
XBAJBUSX
Yeh the gauge wasn't showing anything the when it kick in that's wut it show
Old May 25, 2010 | 07:07 PM
XBAJBUSX's Avatar
XBAJBUSX
It looks like when it get colder it works fine
Old May 25, 2010 | 07:08 PM
chicagodragon
With the system off, it should be about 70-75psi . Running at a high idle, around 40-45 on the low(blue) side. I think around 200ish on the high.
Old May 25, 2010 | 07:15 PM
XBAJBUSX's Avatar
XBAJBUSX
Ok so were is high and low ???
Old May 25, 2010 | 07:22 PM
chicagodragon
What kind of gauge are you using? Is it the one that comes with the can or a real dual set? The low side connection is on the accumulator by the firewall. The high side is closer to the front of the truck on the smaller line.
Old May 25, 2010 | 07:23 PM
chicagodragon
Where are you taking readings?
Old May 25, 2010 | 07:24 PM
chicagodragon
Where are You taking reading?
Old May 25, 2010 | 08:42 PM
XBAJBUSX's Avatar
XBAJBUSX
Yes the one that came with can it only can be connected to low side . Rite by the firewall by the condenser I belive
Old May 25, 2010 | 08:50 PM
oldbird1965's Avatar
oldbird1965
Mine has stopped working a couple of times and the plug on top of the compressor needed cleaned. Then it still would kick on and off. With a running engine and the ac on wiggle the plug and see if the compressor will kick in. On mine I used a plastic tie and pulled it over towards the middle of the engine and it has not failed me sense.
