First Time it Left me Stranded
Old Sep 16, 2013 | 09:00 AM
mechelement's Avatar
mechelement
Throttle cable snapped at the pedal. Waiting for a tow now.
Old Sep 16, 2013 | 09:52 AM
RA31925's Avatar
RA31925
That sucks! I wouldn't count that as my truck leaving me stranded, though. Cables wear out. I've had more than one clutch cable do that to me.
Old Sep 16, 2013 | 10:14 AM
mechelement
$112 at the dealer.
Old Sep 16, 2013 | 03:52 PM
tjc transport's Avatar
tjc transport
i ain't rite
that is why i always have a very small pair of vice grips in the truck. just clamp on the end of the cable and off you go.
i have done it 3 times so far, twice on my 88 and once on my nephews 4.9 powered 88 F-250
Old Sep 16, 2013 | 05:46 PM
mechelement
It's the OEM unit. 28 years old. Probably a bit fatigued.
Old Sep 16, 2013 | 11:27 PM
kobaltblue's Avatar
kobaltblue
Summit racing I payed 35.00. Yep it part of the survival gear vise grips, duct tape bailing wire, long leather shoe strings, fuel filter assorted socket set and fluids.
Old Sep 17, 2013 | 08:16 AM
Chevy_Eater's Avatar
Chevy_Eater
I broke a throttle cable on an old Toyota pickup once, ('67 Stout), I just ran some twine from the carb through the firewall into the cab. Just had to pull on it for throttle. Being a standard transmission, (4 on the tree!), it was awkward to say the least, but it got me home.
Sometimes you just have to MacGyver it.
Old Sep 17, 2013 | 10:26 AM
Orpackrat's Avatar
Orpackrat
Lol, that is about the backup solution I had for my old cars and now my truck. Only difference is my lanyard has a good 25' of 550 cord which is what I use.
Old Sep 17, 2013 | 12:40 PM
Country_boy_2007's Avatar
Country_boy_2007
same thing happened to me, but it broke at the IP...good thing I had a roll of wire and some zip ties
Old Sep 22, 2013 | 11:19 AM
mechelement
The swap took ~45 minutes and that was taking it easy, including filling all of the tires with air and warming up the truck. It's evident, my throttle cable has been stretched and/or frayed for a long time. The truck's response is much more noticeable than before.
Is WD-40 a silicon lubricant suitable for lubricating the throttle cable?
Old Sep 22, 2013 | 12:03 PM
tecgod13's Avatar
tecgod13
No WD-40 would not be silicon based.
You can get spray lube that is silicon based just about anywhere. Oil based lubes attract dirt and grit that will stick to the cable and gum it up and/or wear it down overtime. Silicon lubes don't tend to do that and are recommended for throttle, speedometer and brake cables for that reason.
Old Sep 22, 2013 | 03:04 PM
MPoulson's Avatar
MPoulson
WD-40 evaporates after a while. It eventually dries out like gasoline would, leaving your part dry and crusty. Good for penetrating but not so much for lubing.
Old Sep 22, 2013 | 04:40 PM
mechelement
Bought some CRC silicone spray while at the store today.
92aeroXLT
Aerostar
Sep 12, 2017 06:20 PM
evilci
May 9, 2013 07:25 PM
Brigart
Jul 17, 2011 01:28 PM
jeeph8ter
Bronco II
Apr 19, 2004 06:52 PM
bjoern
Jan 29, 2003 02:26 PM
