I've got a tach cluster from a 97 F350 with a 460 and my friend has a 92 F150 with the 300 and no tach. Can they be swapped over or do I need one from a 300?
What I know is every aftermarket tach I have has a setting for 8 or 6 cyl. I believe they are different. The 97 is an OBDII system the 92 is an OBDI system. So there are differences & also the computers are different. The 92 has an EEC IV the 97 EEC V They are similar but the V is much faster preforms more functions.
The 97 probably isn't OBD-II, but that isnt the issue. The issue is that Ford changed the pinouts for the clusters over the years. 92-93 interchange, 94-95 interchange and 96-97(HD) interchange. Trying to intermix them will cause issues unless the wiring is changed in the dash connector.
I believe in 1996 was the change over to OBD II system. My 95 is an OBD I & if I read correctly 95 was the last year for the OBD I system in the trucks anyway. But like you said the dash clusters are different. I learned something. If I find a tach for mine it will have to be out of a 94-95. Thanks for that info.
It's not like an aftermarket tach, the 8/6 cyl thing is decided externally by the ignition module I think. I have a 300 Six tach on my 460 and it reads correctly.
The non California HD trucks stayed ODB-I to the end. Under 8,500 lbs went to ODB-II in 96. Supposedly the California HD trucks went ODB-II as well but I haven't confirmed that.
What this article fails to mention is the year ranges that are "plug and play"
92 to 93 plug and play
94 to 95 plug and play
96 to 97(F250 and F350 only for 97) same
You can install diffrent year range clusters but you will have to repin the wire harness for the various changes of the cluster. You'll need a good wire digram of both trucks to do it.
The V8/I6 tach is done through the wire harness and is just a grounding wire telling the tach if its for a V8 or I6.
Now from what I've heard is the 1992-1993 Interchange.And the 1994 to 5-1995 Interchange,and 6-1995 to 1996 Interchange.If you have a 1995 you have to check your Build Date,and if you have a Build date of 6-1995 or after you have to use a Cluster with the same Date of 6-1995 to 1996.And if your 1995 has a Build Date of 5-1995 or back you have to use a Cluster with the same Date code of 5-1995 all the way back to 1994.And the reason is Ford changed some of the Circuits in the Clusters Mid-1995.And while they all Physically fit,you will have some things that won't read true,or even work at all.But some Circuits are the same & will work,and I'm guessing that's why some people think they all Interchange.
Thanks
the only difference with mine is that my check engine light came on so I think that it's because its only reading 6 cylinders firing instead of 8. I also completely took mine apart and scraped it for a different color bulb I haven't put in yet.
I doubt that’s the case. I’d be more willing to be you have an “incompatible” cluster and your CEL is actually current to one of the gauges that’s now mispinned.
