Oil pan blues...
Old Sep 12, 2013 | 07:22 PM
Austy's Avatar
Austy
Unhappy Oil pan blues...
Well heck. If it ain't one thing, it's another... So I decided to pull my pan and put in a new gasket and also put a nice new coat of blue on while I had it out, since it got a little chipped when I first put the engine in, so I got to the point where my seals were already destroyed, when I realized I can't get my pan off with the engine in the truck... Anybody know any old secrets for getting it out, or am I stuck carefully scraping the old gasket so I don't get junk in my pan, somehow getting the new gasket around the oil pump and skipping the new paint? '72 F-250, 360, 2x4, C6. Thanks guys.
Old Sep 12, 2013 | 07:42 PM
CougarJohn's Avatar
CougarJohn
You decided to pull the oil pan because the paint was scraped. You wrecked the gasket and now cannot get the pan off because something is in the way. Is that the issue?
That is a new one to me but maybe the guys can help you with advice on pulling the pickup tube to get the pan off without lifting the motor.
Never fix something that is not busted on this old iron.
Old Sep 12, 2013 | 08:07 PM
Austy's Avatar
Austy
Forgot to mention I lost 2 quarts of oil in a day out my pan gasket. That's the driving factor here. It WAS broken and I was going to paint it since it was already coming off. And what "tube" are you referring to?
Old Sep 12, 2013 | 08:15 PM
MIKES 68 F100's Avatar
MIKES 68 F100
it can be done ,
i did it on my original 360
1. jack engine up and put 2x4 blocks between engine and mount to support
2.drain oil and unbolt pan
3. remove to bolts holding oil pump pickup on let it drop on pan
4 wiggle pan out
putting it back together is harder as you have to bolt pickup in place with pan laying on cross member
Old Sep 12, 2013 | 08:19 PM
Austy's Avatar
Austy
That's what me and my gearhead buddies figured, but I figured I'd ask some more experienced folks before going ahead with it. I've never been let down on here before! Thanks Mike!
Old Sep 12, 2013 | 08:43 PM
MIKES 68 F100
you're welcome
be sure to use the wood , last thing you want is an FE squishing your hand/arm
Old Sep 12, 2013 | 10:49 PM
Austy's Avatar
Austy
Yep sir! I've had to panic grab and hold one up before. They ain't light!! My chiropractor kinda chewed me out too...but hey, it saved a buddy!
Old Sep 13, 2013 | 05:50 AM
f100today's Avatar
f100today
Do yourself a favor and buy one of the blue neoprene/silicon steel reinforced one piece gaskets. Reusable as well. 10x better than the multi piece cork crap and WAY easier to install. about $25 to $40 buks but well worth it. Otherwise; good luck.
Old Sep 13, 2013 | 10:29 AM
zak8tac's Avatar
zak8tac
For what its workth, I did this with my 350 chevy once. I used a cork gasket, cut an angle in it so i could get it on the pan. I used RTV to seal up the "cut" area, bolted it up and let it cure before I added oil and started it. Held up with no leaks for 8 years until I sold it. Its easy and cheap to try, well at least easier than jacking up the motor.
Old Sep 13, 2013 | 11:43 AM
f100today's Avatar
f100today
Actually, you can use just RTV as a gasket if you get all the surfaces clean as heck. No gasket needed at all.
Old Sep 13, 2013 | 08:17 PM
1972RedNeck's Avatar
1972RedNeck
Where do you get these? Can you get valve cover gaskets too?
Old Sep 14, 2013 | 05:03 PM
f100today's Avatar
f100today
Summitracing.com or Jegs.com and yes they make them for valve covers as well. Totally worth it.
gordo2
Sep 13, 2013 12:20 PM
Dorsai
Mar 12, 2013 10:48 PM
70-360fe
Feb 11, 2013 10:28 PM
anthony605
Sep 24, 2007 04:39 PM
drew1701
Nov 5, 2006 08:50 AM
