4x4 auto
Old Sep 15, 2013 | 01:32 AM
bert cook's Avatar
bert cook
Question 4x4 auto
did the factory ever put out a 4x4auto for the bumps
Old Sep 15, 2013 | 12:02 PM
tpdaniels's Avatar
tpdaniels
Everywhere I've looked and researched none were made from the factory prior to 1973. Having said that, I have seen several and currently have a 72 highboy with a C-6 Automatic. Mine was a NP 435 4 speed and I did the switch myself. I used a C-6 from a 72 F-250 and put a tail-shaft from a 73 250 4WD, it had the correct mounts for the 4WD lever and no hole for the speedometer cable. I used a steering column from a 68 F250, I put my 72 center shaft in the steering column and also used the 68 linkage rods. Everything worked perfect, you cannot tell it was not factory installed. I reused the rear transmission cross-member and rubber mount, it just had to be moved back about two inches, just drilled out the rivets, drilled new holes and bolted it back it.
Below is a ad from Ford advertising in 1969 showing a F-250 4WD with Cruiseomatic transmission but I was told it was just a advertising trick to see if there was a market to sell them.
pm042070
Jun 24, 2014 09:24 PM
SuperDuty93
13
Jul 13, 2012 08:33 PM
knasen44
Jun 18, 2011 12:50 AM
cornfedp
Dec 18, 2008 06:10 AM
mlf72f250
Aug 31, 2002 05:49 AM
