ignition problems
Old Oct 9, 2013 | 04:31 PM
  #31
crvog81's Avatar
crvog81
Thanks again just finished rebuilding the carb and she runs great
Old Oct 26, 2013 | 04:09 PM
  #32
benbuilder's Avatar
benbuilder
fmc400, I just read this thread. As you know from your help last week, I changed over the front end on my daughters f100. In doing so the casing for male wires to the ignition module crumbled in my hand. I connected them and the truck runs fine. I have a parts truck and I took that module and installed it, the truck had difficulty starting but did start. I know I can do your test, but wondering , shouldn't it "work or not work"? and not be in between?
Old Oct 26, 2013 | 04:27 PM
  #33
montana_highboy's Avatar
montana_highboy
Most of the aftermarket modules don't have the "start retard" feature that Motorcraft modules have...
This feature eases starting by retarding the timing 4-6 degrees during cranking, without it starting can sometimes be difficult.
Old Oct 27, 2013 | 03:52 AM
  #34
benbuilder's Avatar
benbuilder
Montana Highboy, Thank you for your help
Old Oct 27, 2013 | 03:06 PM
  #35
fmc400's Avatar
fmc400
MSEE
The components of the module are subject to stress and age, which can lead to reduced primary current and inaccurate dwell. The module can very much be in between or fail intermittently. My recommendation is to use OEM Motorcraft modules. They are on the expensive side, but will outlast the truck. I don't run anything else.
Old Oct 27, 2013 | 04:36 PM
  #36
benbuilder's Avatar
benbuilder
Thank you fmc400
Harbormaster1976
Jun 15, 2014 08:42 AM
irishguyincc
1983 - 2012 Ranger & B-Series
38
May 2, 2006 08:02 PM
ford351c
Electrical Systems/Wiring
Jun 22, 2004 01:33 PM
steve83
Nov 15, 2002 05:21 PM
JTed111
Sep 21, 2002 08:29 PM
