ignition problems
Old Sep 9, 2013 | 12:39 PM
crvog81's Avatar
crvog81
ignition problems
Hello all I am having trouble determining why I cannot get spark to the distributor. it is a 1976 F-100 it has sat for about 6 months and now it will not get spark. The module is good the coil is good and the distributor is good. I have checked everything with a voltmeter and have gotten the specified readings. Any help would be much appreciated.
Thanks
Old Sep 9, 2013 | 12:43 PM
caliRangerXLT's Avatar
caliRangerXLT
have you got a good ground everywhere?
Old Sep 9, 2013 | 12:49 PM
fmc400's Avatar
fmc400
MSEE
How do you know the module, coil, and distributor are good? What specifically did you check, how did you check it, and what were the results of those tests? Obviously, if everything were "good," you wouldn't have a problem, so you have to help us understand what you're working with.
That's a pretty ambiguous statement. I don't know where to look if I'm supposed to look "everywhere." The ignition system references one signal ground point, which is in the distributor. Many folks on the forum throw out "ground" in reference to ignition or lighting problems without making it clear as to why, other than to say that ground problems lead to weird issues. While that's true, it's ultimately not entirely helpful.
Old Sep 9, 2013 | 01:04 PM
crvog81's Avatar
crvog81
hello cali I do have a good ground I think. I could have over looked something. FMC 400 I used this link to do some trouble shooting 1975-79 DISTRIBUTORS & IGNITION all of the results are as desired still no spark.
Old Sep 9, 2013 | 01:32 PM
crvog81's Avatar
crvog81
update double checked and according to the instructions in the doc above it is saying the magnetic pickup is bad how do you fix this or do you replace the entire distributor?
Old Sep 9, 2013 | 01:34 PM
crvog81's Avatar
crvog81
update double
Old Sep 9, 2013 | 02:16 PM
fmc400's Avatar
fmc400
MSEE
You can replace the pickup by pulling off the veined armature without removing the distributor itself.
Old Sep 9, 2013 | 02:28 PM
Rico47635's Avatar
Rico47635
You will need a special tool to replace the pickup coil. Any auto parts store should have it in stock. Be very careful. If you drop a screw into the distributor you will have to take the distributor out.
http://www.supermotors.net/getfile/8...ule-wrench.jpg
Old Sep 9, 2013 | 03:19 PM
crvog81's Avatar
crvog81
could you use a gear puller or two screwdrivers to take the amature off? if so how much force is required to put it back together?
Old Sep 9, 2013 | 05:22 PM
fmc400's Avatar
fmc400
MSEE
You can do it with two screwdrivers, but be careful. Since there's a tool for it (hadn't seen that before), I'd use that instead.
Old Sep 16, 2013 | 01:33 PM
crvog81's Avatar
crvog81
help help help
update I have replaced the magnetic stator and the coil still no spark. what could my problem be? any help is much appreciated
Old Sep 16, 2013 | 01:51 PM
fmc400's Avatar
fmc400
MSEE
Connect a test light from the negative terminal of the coil (TACH TEST) to clean, unpainted metal on the engine (ground). Crank the engine over with the key, and the light should BLINK. Report your results.
Old Sep 16, 2013 | 03:36 PM
crvog81's Avatar
crvog81
the light stayed on and did not flicker.
Old Sep 17, 2013 | 12:35 PM
crvog81's Avatar
crvog81
the light stayed on and did not blink. what would be the next step?
Old Sep 17, 2013 | 08:00 PM
fmc400's Avatar
fmc400
MSEE
That means the coil is not getting switched, either because the module isn't getting power, it's not getting a trigger, or it's bad.
Disconnect the 2-terminal connector at the ignition module. The RED with BLUE stripe wire coming from the TRUCK (would go to the WHITE wire of the module) should be hot with the key in START. The other wire (WHITE) coming from the TRUCK (would go to the RED wire of the module) should be hot with the key in RUN.
If you have 12 volts in both cases, then disconnect the 4-terminal connector. There should be 400 to 700 ohms between the ORANGE and PURPLE wires coming from the TRUCK. The BLACK wire coming from the TRUCK should have continuity with ground (no more resistance than that of your meter leads).
Since these are FEMALE connectors you're probing, you may need some help with a small wire inserted into each terminal. Use caution not to damage the terminals. If all that checks out fine, then the ignition module may be bad, or the connectors to the module could be corroded.
