Sponsored by: Auxito
R.a.b.s. Sensor Testing
Old Jun 17, 2003 | 08:56 AM
luckild's Avatar
luckild
Still have a problem,97 f-150 4x4 .ABS LIGHT ON AGAIN. Replaced sensor recently, still have code 9. high speed sensor resistance. Anybody have test info on this. Any info on this will help.
Old Jun 18, 2003 | 12:06 AM
Racerguy's Avatar
Racerguy
Measure the resistance between the anti-lock electronic control module (in the dash, to the left of the radio and hard to get at) circuit 519 (LG/BK) and circuit 523 (R/PK) while shaking the wire harness.
Is the resistance steady and between 800-3500 ohms?
In not then you have a problem. if the resistance is less then you have a short, if it's more you have an open....quite likely in the wiring to the sensor from the frame.
Old Jun 18, 2003 | 03:41 PM
luckild's Avatar
luckild
worked like a champ,broken by axle.also saw brake flex hose almost worn threw.replaced before it broke.others might want to check theirs also.thanks RACERGUY. your the BEST.
Alcaeus
Aug 6, 2016 09:48 AM
Sancho
1997 - 2003 F150
Oct 31, 2015 05:30 PM
ftowelding
6.7L Power Stroke Diesel
Aug 1, 2015 11:49 PM
dalberti
1997 - 2003 F150
Mar 7, 2014 08:22 AM
