6 SPD LOST GEARS
Old Sep 7, 2013 | 08:40 PM
quality1construction's Avatar
6 SPD LOST GEARS
I just lost 3rd and 4th gear in my 6 spd trans this evening, transmission was a reman 15 months ago and I just now put over 10k miles on it. Full of Mobil 1 ATF and have a Dieselsite trans filter installed . Any ideas what went wrong? R,L, 1, 2, AND 6TH seem to work fine.
Old Sep 7, 2013 | 09:06 PM
F350-6's Avatar
F350-6
Hope you got a 16 month warranty. Sounds like it needs to come apart to fix this. But your OP leaves one too many gears to chance. It's either L-5 or 1-6. Is the problem shifting up and down, or just in one direction? Depending on which 2 of the 3 gears that are missing, it could be different things, but unfortunately, they all lean toward the same thing. Pull the transmission and replace the broken stuff.
Old Sep 7, 2013 | 09:16 PM
Technically on the shifter its L, 1, 2, 3, 4 and D. Based on that 3 & 4 are gone. Was driving up the road in D, heard a heck of a grinding/clanking, truck jerked, shifter locked up, and they are gone. Shifting into those 2 are like being in neutral. Just wondered if anyone else has had a similar problem.
Old Sep 8, 2013 | 07:37 AM
F350-6's Avatar
F350-6
You could try pulling the shifter and top plate off and looking down inside there from in the cab, but if a shift fork or something came off, I'm guessing it's in a spot you won't be able to reach.
Old Sep 8, 2013 | 09:56 AM
timmyboy76's Avatar
timmyboy76
bummer to hear, man...seems to be the month of the zf6 breakdowns.
Old Dec 14, 2013 | 05:25 PM
anotherfordguy's Avatar
anotherfordguy
Sounds like what happened to mine. I am rebuilding mine right now. The bearing between the input shaft and main shaft failed and broke the 3-4 syncro hub.
89scott
Feb 28, 2016 03:16 PM
Engine
Nov 8, 2007 08:03 AM
jdhv002
Bronco II
Sep 18, 2007 03:10 AM
fordtrck302
Jul 19, 2005 06:58 PM
gimps
Bronco II
Apr 21, 2000 11:43 AM
