ABS light
Old Sep 6, 2013 | 11:11 AM
Turfzilla's Avatar
Turfzilla
ABS light
I'm out on the hiway today towing to the lake. Abs light came on about half way there. First time this has happened. No codes.
What could it be? Will it hurt to keep driving?
Old Sep 6, 2013 | 08:24 PM
Turfzilla's Avatar
Turfzilla
Anyone? What causes the ABS light to come on ?
Old Sep 6, 2013 | 08:34 PM
Mowing Man's Avatar
Mowing Man
Mine is on too. It's because of an internal sensor in my wheel assembly. There's also a sensor that can be removed from the assembly, and Ive also had chafed wires going to the assembly that will trigger it. Check both front tires. Could be more but those are ones I know about.
Old Sep 6, 2013 | 08:35 PM
th67ss's Avatar
th67ss
Could be a bad sensor, or a bad unit bearing assemblie. I drove mine for a while with no issues. As long as you don't hear grinding you should be good to go.
drguitarum2005
2004 - 2008 F150
Oct 15, 2013 08:30 AM
doubleford
Oct 29, 2010 07:24 PM
herman2001
Sep 15, 2006 03:56 PM
edub32
53
Feb 5, 2006 09:05 AM
