HELP
Old Sep 5, 2013 | 07:32 PM
Jester F-350's Avatar
Jester F-350
HELP
Ok so I have a 2003 F-450 7.3L it will crank and not start, I have read a thousand ideas on here and can't wrap my head around this. When cranking, the tach and oil pressure gauge do not move, I have replaced the CPS as it was quite cheap and easy to do. I drained the fuel bowl and turned the ignition on and it fills up. ALso disconnected the hpop sensor and rolled it over, still nothing! Where do I go from here?
Old Sep 5, 2013 | 07:36 PM
Tom's Avatar
Tom
Hi Jester F-350,
I'm going to send this one down to the 7.3L Powerstroke forum, the folks down there will be better able to help you out.
Old Sep 5, 2013 | 07:43 PM
carltonwebb's Avatar
carltonwebb
Do u get a wait to start light?
How much fuel is in it?
Did it quit running going down the road or did it just not crank one day?
I assume by HPOP sensor, you mean the icp sensor in the front of the driver side head?
Old Sep 5, 2013 | 07:48 PM
Jester F-350
GLow plug light behaves normally half a tank of fuel. Just picked it up from a friend who said it just quit. And yes I ment the ICP sensor.
Old Sep 5, 2013 | 07:55 PM
carltonwebb
I should have asked too if it had a power chip on it. check all the fuses you can find. pcm is coming on to some point to get wts light
Look at the back of the IPR and see if the tin nut is still on. IF it comes off, it will quit running.It can also get dirty inside and not actuate properly. Maybe unplug it and check for voltage with the key on. Beyond those checks, you are gonna have to have a good scanner to read live data to get much further.
Old Sep 5, 2013 | 08:08 PM
Jester F-350
No chip, completely stock, Now would the IPR effect the tach and oil pressure gauge? the only thing I haven't done is remove the IPR.
Old Sep 5, 2013 | 08:09 PM
Whitey Ford's Avatar
Whitey Ford
FTE-Spread The Knowledge
Have you checked the batteries and battery terminals?
Old Sep 5, 2013 | 08:14 PM
Jester F-350
Yes, I hooked it up to a heavy duty booster aswell as charged both batteries over night. Scanned it, no codes. However my scanning equip won't give me live feed data.
Old Sep 5, 2013 | 08:21 PM
carltonwebb
Not all of these show on tach when cranking. The oil psi should come up on a real long crank but mine sometimes does not go up until its running. If you pull the plug out of the top of the hpop reservoir and there is oil almost to the top, then lpop is working. If reservoir is empty, refill it and try to crank.
Old Sep 5, 2013 | 08:23 PM
Jester F-350
Ok so the reservoir was bone dry. filled it and cranked but still no change. watching to see how long reservoir takes to drain down while sitting.
Old Sep 5, 2013 | 08:26 PM
carltonwebb
It does have oil in it?
It will take a good long crank to get it bled out to crank. If the LPOP went out, it will cause that reservoir to not get replenished. Check to see if its building LPOP psi.
Old Sep 5, 2013 | 08:36 PM
Jester F-350
LPOP? where and how would I check that? It had no oil in the HPOP reservoir so I filled it up.
Old Sep 5, 2013 | 08:43 PM
jeffreyt's Avatar
jeffreyt
Looks like this one is just about figured out... The lpop is the low pressure oil pump. There is a dummy gauge on the dash that indicates whether or not there is low pressure oil pressure being build. When I say dummy gauge, it simply indicates if there is pressure or not, won't indicate how much.
Also, it's not a bad idea to confirm that the fuel pump is working when the key is first turned on. If not, we have a second rabbit to chase.
Old Sep 5, 2013 | 08:44 PM
Bigcat350's Avatar
Bigcat350
You need at least 500 psi injection oil pressure before it will start. If the IPR is stuck or bad you may not get enough pressure. Simple check with AE.
Old Sep 5, 2013 | 08:48 PM
carltonwebb
https://www.ford-trucks.com/forums/9...p-install.html
That is great write up on how to change but i was looking for picture of where u test it at but cannot find it.
