boost sensor
Old Sep 4, 2013 | 10:15 PM
djanzen's Avatar
djanzen
boost sensor
Hello guys
my 03 6.0 has an issue with the boost (mapp) sensor
I have a bully dog outlook monitor on it for gauges and when it is cold the boost is all over the place, from 2-35 psi jumping around steady, when it warms up it drops to zero and stays their.
I know this is a wiring issue and i am just looking for some info on where to start looking.
Old Sep 5, 2013 | 12:13 AM
BLADE35's Avatar
BLADE35
Sounds like a Bad Map sensor
Compare BARO MAP EBP at KOEO are they the Same
Then Get it Hot and Do the KOEO Thing Again are they the Same
Has the CEL turned on at any Time??
Any DTC??
Old Sep 5, 2013 | 06:29 AM
djanzen's Avatar
djanzen
Any DTC??
Done! map has been changed I thuoght that it was bad at first also
no cel
only p1000
Old Sep 5, 2013 | 06:37 PM
djanzen's Avatar
djanzen
Can anyone tell me what the values should be on the wiring to the map sensor?
it is a three wire pressure sender, so it should be
1, V+ (not sure if it is 5v,8v or 12v?)
2, V+ voltage output which would vary with boost pressure
3, v- ground
KOER and KOEO
I am sure this is a wiring issue. it will be rubbed though or broken somewhere but i need to know which one to look for.
Old Sep 5, 2013 | 06:43 PM
BLADE35's Avatar
BLADE35
https://www.ford-trucks.com/ford-man...%20diagram.pdf
Old Sep 5, 2013 | 10:27 PM
djanzen's Avatar
djanzen
Thanks Blade
Old Sep 14, 2013 | 01:53 PM
djanzen's Avatar
djanzen
I tested the wiring to the map and it was good, exactly as the wiring diagram showed.
here is my testing this morning
First pic is 2500rpm no load
second pic is idle
third id dtc
The problem is low power, get some black smoke when accelerating from a stop.
seems to get worse as it warms up.
for some reason my AE does not have exhaust back pressure? weird but i have looked forever trying to find that setting
Old Sep 18, 2013 | 07:19 AM
djanzen's Avatar
djanzen
Well My truck went from a low power condition to a hot no start condition!
On my way home last night I was accelerating up a overpass and all of a sudden it had NO power at all. when i got home i shut it off and tried to restart, no luck
two hours later i when out and it would start, guess i am doing some HPOP work!
Old Sep 18, 2013 | 07:38 AM
npccpartsman's Avatar
npccpartsman
second pic is idle
third id dtc
03 engines use an inferred EBP reading. The sensor is there but it's been taken out of the strategy on those engines so the PCM doesn't see it.
Shaun Fed
6.4L Power Stroke Diesel
Jul 25, 2019 05:12 PM
JGRNAUT_7.3L
Dec 2, 2017 11:07 AM
Tugly
May 9, 2014 07:49 AM
baredog26
Dec 9, 2010 11:30 AM
bobrc
Aug 24, 2008 12:56 PM
