ignition module
Old Sep 3, 2013 | 10:40 PM
austinlittle34's Avatar
austinlittle34
ignition module
my ignition module went out it my 1990 f150 4.9 and i want to take it off with out pulling the distributor and i have heard that in order to get the retaining screws out you have to have a special socket or you can use a allen wrenches any input?
Old Sep 4, 2013 | 03:23 PM
Conanski's Avatar
Conanski
You need a thin wall 7/32 socket for those bolts.. allen key won't work, but I don't know if it is possible to remove the bolts with the distributor in an I6 motor, I just know it's not possible on the V8s.
Old Sep 4, 2013 | 03:27 PM
firerescue9's Avatar
firerescue9
It is possible in a V8, you just loosen the hold down and rotate it all the way. Thus, your timing is now completely off...
They are litterly like 7 bucks at autozone/advanced
Old Sep 4, 2013 | 09:37 PM
austinlittle34
havent got to it yet i had worked on exhaust today but im going to try to grind down the outside of 7/32 to fit in side and ive heard its a little technique to pull it after the i get the screw out thanks for the input guys
Old Sep 4, 2013 | 11:18 PM
oldford65's Avatar
oldford65
They have a special tool for it. Auto zone and all the others have it. No need to remove distributor.
Old Sep 5, 2013 | 12:15 AM
ford2go's Avatar
ford2go
Not a problem taking them off of the distributor in an I6
Sometimes they sell the sockets as 5.5 mm
Be sure that you put the heat conductive grease on the module when you install
it -- the new one should have a tiny tube of the stuff.
hj
Old Sep 5, 2013 | 07:37 AM
MT4x4guy's Avatar
MT4x4guy
If you can, make sure and mark your distributor position, that way when it gets moved you can at least get it back to close and then fine tune the timing once you have the new part in.
Dace
18
May 30, 2014 11:33 AM
bettamanpj
Aug 20, 2003 08:12 AM
torquemeister
Apr 1, 2003 10:57 PM
billybob1
Jul 31, 2002 08:32 PM
dale
Mar 1, 2000 12:54 PM
