module
Old Jul 31, 2002 | 05:47 AM
billybob1's Avatar
billybob1
module
....86 f150 302...
Ignition module is mounted on the distributor. Is there a way to remove and replace without pulling distributor? It looke pretty tight.
BZ
Old Jul 31, 2002 | 09:06 AM
Agent86's Avatar
Agent86
module
Old Jul 31, 2002 | 09:48 AM
desperado_18_2000's Avatar
desperado_18_2000
module
it is possible to remove the tfi, autozone sells the socket to get into the screws/bolts on it. you'll probably have to losen the distributor and turn it a little to get at all the bolts. i just got done doing this on a buddy of mines truck a couple weeks ago. its real simple
HTH!
Old Jul 31, 2002 | 08:32 PM
topo4u2's Avatar
topo4u2
module
Dont forget to mark the distributer before you spin it or you will need a timing light. It is a bit of a bitch to get at but as the last post mentioned it is a lot easier with the correct tool, either and allen key or torx.
bowling1
Aug 24, 2014 07:37 AM
buddywest
Jun 27, 2006 04:14 PM
danlee
May 19, 2005 07:20 AM
Bobber
Apr 22, 2004 07:31 PM
muddawg
Electrical Systems/Wiring
Mar 31, 2002 09:02 PM
