ignition module help
Old Apr 1, 2003 | 07:28 PM
torquemeister's Avatar
torquemeister
I am replacing my (86 F150 302) TFI ignition module (distributor side mounted), and I'm unable to loosen the two bolts holding the module on. I can turn the distributor enough to barely see them (enough to know that they aren't screws, torx, or allen bolts), but none of my sockets grab the bolt to turn it. What size are these bolts, and is there some easier way to unscrew them (other than taking the distributor off)?
thx-
TM
Old Apr 1, 2003 | 07:38 PM
Franklin2's Avatar
Franklin2
You can buy a special socket to get them off. Or do what I did and grind one of your sockets down on the outside so it will fit up in the hole.
Old Apr 1, 2003 | 07:49 PM
torquemeister
thanks, do you know the name of the special tool? Does Autozone carry it?
thanks!
TM
Old Apr 1, 2003 | 08:53 PM
Franklin2's Avatar
Franklin2
Probably. Here's one from advance auto
Old Apr 1, 2003 | 10:57 PM
torquemeister
Thanks, that $5 part saved me tons of frustration, and made the module change a 5 minute process!
TM
