Has anyone installed this on a 2012 F150 without the Tow Package.
I have been reading all I can find, but most of the OEM's I find are going on trucks with the towing package. I have NOTHING!!!
I know I can with Prodigy, but the OEM from Ford reads good.
Get a light and an inspection mirror and look around behind the dash where the controller is supposed to go. If you see four wires together write down the colors and I'm sure some body on this site can tell you if they are the ones. Best, CB
Thanks CB: I am going to check everything out, as soon as I get it back from the dealer shop next Thursday or Friday,if they can get the parts, for the Diff. whine.
I have asked the Dealer Parts dept. to quote me everything I will need to put the OEM on, but who knows what they will come up with.
Dealer says all I need is a Contol Module and a 9L3Z15416A Hitch Kit.
Behind the Bezel, I found a plug, plugged into the Coin Holder. Has a black, blue, and 2 white wires. IS THIS IT?
There is a box on the right side top of the rear axle. with a wieing connection from all the light wire harness going into it.
I haven't found a way out of the box for a plug in yet. (Fat old men need more room) But if these are where the connections need to be made, I am A O K for the ford TCB.
All replies are greatly appreciated. Thanks Jim
Update: I found the TCB plug taped close to the OBD11. I have a 4 plug connector at the rear bumper already. Have not figures where the brake plug will plug in yet. Hitch should be here 9/05, and I will frop the spare and have a look while I am under there.
Reason: Update:
I have been searching, and came up on this from another F150 site.
"Hey guys, Josh from Tasca here. If you post your VIN # here or e-mail me at jlaliberte@tasca.com I will let you know which trailer brake controller you need for sure."
Apparently on my 2012 XL, all I need is the TBC and a new rear harness Kit
Part # 9L3Z15A416A
Excellent, glad to hear it should be an easy addition. I believe you will still need top have the dealer flash the computer so it will recognize the new TBC before it will work. Good luck
