Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Air Intake and Exhaust Guides
- Air Filter Reviews
Reviews and comparisons of top products
K&N Air filter worth the investment?
on
My 5.0L has been almost 1yr on the road and thinking of changing the air filter...never owned a cleanable & reusable one. $54 for a K&N at JC Whitney, and the aftermarket paper ones range from $7-$12.00 on EBAY.
So i can get 7 paper ones for 7 years of use for about the same price as a K&N, and after that I will probably get a new vehicle...so is there some other advantage to these? I read the K&N FAQs and don't see much if any price benefit. Am I missing something?
EBAY
Ford 7C3Z-9601-A Motorcraft FA1883 Baldwin PA4323Manufacturer Part Number: CA10262Other Part Number: Hastings AF1333 Napa 9883 Wix 49883 Puro. A35642
FRAM Part Number CA1026
Product Type Flexible Panel Air
Product Height 2.64"
Product I.D. 9.93" (Width)
Product O.D. 10.48" (Length)
Competitor Cross Reference
BALDWIN PA4323
CARQUEST 83883
DEFENSE DA10262
DEFENSE DA10262
FORD 7C3Z-9601-A
HASTINGS AF1333
MICROGARD MGA10262
APPARENTLY FITS
F150-350
V10-6.8L F/inj. (30V) SOHC (Y) [2010-2008]
V6-3.5L D.I. ECOBOOST Twin-Turbo (T) [2011]
V6-3.7L F/inj. (24V) DOHC Flex Fuel (M) [2011]
V8-4.6L F/inj. (16V) SOHC (W) [2010-2009]
V8-4.6L F/inj. (24V) SOHC (8) [2010-2009]
V8-5.0L F/inj. DOHC Flex Fuel (F) [2011]
V8-5.4L F/inj. (24V) SOHC (5) [2010-2008]
V8-5.4L F/inj. (24V) SOHC Flex Fuel (V) [2010-2009]
V8-6.2L F/inj. (6) [2012-2010]
V8-6.2L F/inj. Flex Fuel (6) [2012-2011]
EBAY
BALDWIN PA4323
CARQUEST 83883
DEFENSE DA10262
DEFENSE DA10262
FORD 7C3Z-9601-A
HASTINGS AF1333
MICROGARD MGA10262
APPARENTLY FITS
F150-350
Years ago, I had a K&N filter on my '91 5.0L Mustang. I'm not sure I would want to have another one, though, since it takes time to properly maintain them. If I had other reasons to improve the "breatheability" of my intake system, such as forced induction, then I may consider it. But, for a daily driver, I think I'll just stick to paper filters. I don't have extra time to devote to the cleaning process. Also, the K&N may be re-usable, but you still have the "maintenance cost" of the K&N Filter Oil and Cleaning Solution.
Unless you are running forced induction, you won't benefit performance wise from a K&N on these new trucks (or a so called cold air kit for that matter...) and even then you are risking destroyed impeller blades from the increased dirt allowed into the intake. And if not oiled properly, you will gum up your MAF sensor, causing poor performance and mileage. I like the cold air and K&N filter on older vehicles with natural aspiration, but not on my newer vehicles.
I have 185000 miles on my 2002 f250 with the V10 and have had the same K&N airfilter on it without any MAF issues. It is the original. It is always clean. Yes there is maint. on it but it really isn't too bad. They are correct about over oiling it. Don't do it. If you follow the directions it is pretty easy to right.
Chris - consider yourself lucky.
Here is a test on Bob is the Oil Guy: Air Filtration Test K&N fails to even get close to it's marketing hype.
And here's diesel testing: http://www.dieselbombers.com/chevrol...r-testing.html Once again, K&N is a total failure at filtration.
Someone a few posts earlier mentioned the Volant unit. They are now making units with the Donaldson PowerCore element that is the same type as used from the factory in the Powerstroke Diesels since about '03. A VERY good filter with very little restriction. If you're looking into aftermarket units you could do a lot worse than that unit.
Donaldson filters are about the best on the market. They are used in the M1-A1 Abrams tanks. We also use them on our compressor packages. Not cheap, but top shelf all the way. Put a K&N on my 05 PSD F250 6.0L. I had it on the truck for exactly 1200 miles (1 trip) and it came off. I never used it again. I went back to the stock Donaldson.
