Sponsored by: Real Truck
Level 2.5 Alignment
Old Aug 29, 2013 | 09:33 AM
Rudiak's Avatar
Rudiak
Level 2.5 Alignment
If I do a 2.5 front level and 4 inch tapered blocks in the rear, will I need new shocks too? Will I need a front end alignment? Will I need an adjustable track bar?
Old Aug 29, 2013 | 10:13 AM
straight axle's Avatar
straight axle
My 13 f250 with a 2.5 inch kit and stock track bar went to the alignment after the install and it was still in spec.
Tires are so expensive its worth it to check the alignment anyway.
Old Aug 29, 2013 | 10:57 AM
SuperDutyScaler's Avatar
SuperDutyScaler
a good truck repair shop will do an alignment check for around 50 dollars. The local guy i go to (only had my truck checked once) charged me 50 dollars after i installed my 2" front level spring on my 2004 F350. i took measurements before and after and adjusted my tract bar and drag link myself before going to the shop.... he said i did good because the truck was well within spec, if not he said it could have been almost 200 dollars if they had to adjust everything to get it back into spec
Old Aug 29, 2013 | 01:11 PM
Rudiak's Avatar
Rudiak
Do I need new shocks or shock extenders?
Old Aug 29, 2013 | 05:17 PM
Hotpocket's Avatar
Hotpocket
not sure about the shocks, i would say no...but you are supposed to have flat blocks on a cc sb not tapered
Old Sep 30, 2013 | 01:50 PM
Rudiak's Avatar
Rudiak
Should I get an adjustable track bar? Or a drop bracket? What size?
dryan
Oct 27, 2018 09:13 AM
lasallen
Apr 4, 2018 09:07 PM
fmuguira
Jan 7, 2018 05:00 PM
zonedar
6.7L Power Stroke Diesel
15
Aug 9, 2012 11:28 PM
swat
17
Oct 22, 2008 11:13 AM
