1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Steering Pump filter - which hose ?
Old 08-27-2013, 08:01 PM
Jack Frost's Avatar
Jack Frost
Jack Frost is offline
I have put a new steering pump on my 2002 f250 and all new hydraulic hoses. I plan to install a steering pump filter on the system to help protect it from anything that is not steering pump fluid.
There are two intake ports to the steering pump. One is near the bottom of the pump and takes fluid from the steering pump cooler after it has left the steering gear. The other intake port is near the top of the pump and takes fluid from the booster.
My question is - which hose would be better to put a steering pump filter on? Is there anything wrong with putting a filter on both? I imagine the first intake hose is constantly circulating fluid and the other only circulates it when the steering wheel is used.
Old 08-27-2013, 10:09 PM
Shake-N-Bake's Avatar
Shake-N-Bake
Shake-N-Bake is offline
The return hose is low pressure so that is your best choice. I wouldn't cut either of the high pressure hoses. Many aftermarket PS pumps have an internal magnetic filter...I think the OE pumps just had a screen and it eventually gets clogged over time. Took my truck avout 300k miles before the screen clogged enough to inhibit performance.
My $0.02....
Old 08-29-2013, 08:43 AM
Jack Frost's Avatar
Jack Frost
There are two return hoses to the power steering pump and I was wondering which one should be used for the filter.
Old 09-28-2013, 10:41 PM
SpringerPop's Avatar
SpringerPop
SpringerPop is offline
Shown somewhere in this article is the one I used:
SpringerPop's Hydraulic Filter
Pop
Old 09-29-2013, 07:28 PM
Jack Frost's Avatar
Jack Frost
That will be my spring project. Thanks ...
dvdgzzrll
10-17-2010 06:47 PM
99F-250lova
02-15-2006 11:24 AM
dnakirks
03-31-2004 08:52 PM
aj5601
1978 - 1996 Big Bronco
09-18-2002 12:05 PM
noey
07-10-2001 05:30 PM
Quick Reply: Steering Pump filter - which hose ?
