1969 Power Steering Issues
Old Oct 13, 2010 | 04:34 PM
dvdgzzrll's Avatar
dvdgzzrll
Hello FTE!
Can I bypass my power steering without hurting anything?
While waiting for my PS hoses, I ran my PS pump dry and now that everyting is hooked up, the Pump whines loud and everything is really hot.
The powersteering works good, but the pump and hoses are really hot and it whines fairly loudly at increased rpms.
I'm reluctant to bypass it, because when it wasn't working my steering was really unpredictable. I tightened up the steering box nut a half a turn and that seemed to help a lot, but I'm wondering if no PS Pump will affect the steering?
Will no PS Pump make my steering loose or should it be ok? I was also thinking that maybe I have the wrong type of fluid? I added a 3rd party PS fluid.
This most likely a temp solution until I can afford a new PS Pump.
Thanks for your help!
Old Oct 13, 2010 | 05:05 PM
carpenter547's Avatar
carpenter547
here :)
Originally Posted by dvdgzzrll
Hello FTE!
Can I bypass my power steering without hurting anything? only your truck if you crash cuz the steering is very hard.
While waiting for my PS hoses, I ran my PS pump dry and now that everyting is hooked up, the Pump whines loud and everything is really hot. if you cooler is not connected connect it. if it is hot mabey add a cooler to it. the whine is normal for some of these pump units known as the "ford growl"
I'm reluctant to bypass it, because when it wasn't working my steering was really unpredictable. I tightened up the steering box nut a half a turn and that seemed to help a lot, but I'm wondering if no PS Pump will affect the steering? have heard that is what it is for but it is better left to a trained mechanic to do it as over tightening can destroy the whole gear box.
Will no PS Pump make my steering loose or should it be ok? I was also thinking that maybe I have the wrong type of fluid? I added a 3rd party PS fluid.ford and the pump manufatures recomend using type F tranny fluid to your power steering pump. i doubt any thing will hurt it though but when in doubt on our old tucks add type f.
again you can drive it with out power steering with out damaging the unit i would take the belt off of the power steering pump if it is dry however be careful the old trucks are heavy and there is a reason they came with power steering and no disconnecting the power from the steering is not the same a a manual steering box they are geared to be gear assisted.
1234567890
Old Oct 17, 2010 | 06:47 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Two totally different P/S systems were used in 1969.
Before serial number D96,001 = Bendix.
From serial number D96,001 = Ford.
The P/S hoses used w/Bendix P/S are different w/Ford P/S, as is the P/S pump.
The serial number is the last 6 digits of the VIN.
chiefsfootball
Feb 2, 2015 02:53 PM
Mike SVOR
6.4L Power Stroke Diesel
Nov 26, 2013 08:54 AM
vettdvr
13
Sep 14, 2008 10:40 AM
