Exhaust leak?
Old Aug 29, 2013 | 10:52 PM
Curt's05's Avatar
Curt's05
Wiser by FTE
Originally Posted by MisterCMK
What up-pipe did you go with?
Went with oem, installed tonight that went in good. Now have exhaust leak, weird whistle i thought it was from the exhaust into the turbo. Checked that and still leaking! Re checked the turbo out down pipe still leaking! Im looking for idea's as to where the leak is?
Old Aug 29, 2013 | 11:10 PM
MisterCMK's Avatar
MisterCMK
Can you get your hands in there to feel for the leak?
Old Aug 29, 2013 | 11:33 PM
Yahiko's Avatar
Yahiko
If you don't want to put you hands back there try a string on a stick.
Sean
Old Aug 30, 2013 | 06:12 AM
Curt's05's Avatar
Curt's05
Wiser by FTE
Ive had the turbo off like 6-8 times and never had a leak, so im thinking mayme the up pipe is leaking? I was working below and a friend on installing on top. Maybe he didn't get the bolts tight! It sucks because you have to remove the turbo!
Old Aug 31, 2013 | 04:51 PM
Curt's05's Avatar
Curt's05
Wiser by FTE
My leak was coming from the egr block off cap/gasket, used my custom fish rod to it!
Old Sep 1, 2013 | 01:56 PM
MisterCMK's Avatar
MisterCMK
The IPR pipe doesn't have that problem.
Old Sep 2, 2013 | 05:52 AM
npccpartsman's Avatar
npccpartsman
IPR has a really nice stainless up pipe. It has thick flanges just like the OEM one.
If I had to buy one that's the one I'd go with too. The OEM type flange is not only heavier it's easier to get a flex head wrench on to tighten up the bolts. The PMM I got to try was very cheaply made and the EGR cooler delete pipe leaked.
Old Sep 2, 2013 | 10:35 AM
Curt's05's Avatar
Curt's05
Wiser by FTE
good to know, i hope i never have to do turbo exhaust work again Do you like my Custom Mechanical Exhaust Leak Detector
Rellick
Jun 19, 2014 11:16 AM
throwdown
Jan 13, 2010 02:15 PM
crazymut
Aug 2, 2009 11:44 PM
Visseroth
26
May 26, 2009 02:37 PM
ForemanES
Feb 16, 2007 04:50 PM
