2004 Ford Excursion Tires Feathering/ Cupping
Old Aug 23, 2013 | 12:06 PM
dvrjump's Avatar
dvrjump
Would anyone know the cause of my New Tires are starting to Cup and or Feather pretty bad. Is this a aligment issue? Camber? I am just not sure because it feels like the truck drives Normal...
Old Aug 23, 2013 | 02:26 PM
wpnaes's Avatar
wpnaes
Gotta pic? On inside? Outside? Miles on the truck? 4x4? Could be a number of things. A pic will help a lot.
Old Aug 23, 2013 | 03:13 PM
BEARDOWN's Avatar
BEARDOWN
Might be bad shocks. How many miles on them?
Old Aug 23, 2013 | 05:38 PM
dvrjump's Avatar
dvrjump
The truck has 106,000 miles on it and the tires have around 10,000 miles them. The truck is a 04 Ex 4x4 with a 3 1/2" Front lift with Airbags in the rear.
Old Aug 23, 2013 | 06:13 PM
wpnaes's Avatar
wpnaes
Things to check: shocks, alignment, ball joints, unit bearings, tie rods, steering damper. Is the wear on the inside edge of the tire?
Old Aug 23, 2013 | 06:24 PM
dvrjump's Avatar
dvrjump
Its in the middle of the tire, as soon as I get a chance I will snap a pic of them. I checked all tie rods, Ball Joints, and bearings. I am not sure if its happeing because Im only running 60 PSI and the tire calls out for 80??
Old Aug 23, 2013 | 06:27 PM
wpnaes's Avatar
wpnaes
Nah, 60 is a little high IMO; if I'm not towing, I run 'em at 50psi. E rated tires? Similar wear front/rear? 80 is max, no need to run em that high when empty.
Old Aug 23, 2013 | 06:36 PM
dvrjump's Avatar
dvrjump
Yes they are E Rated, Maybe I will drop them down to 50. The wear is just in the front..
Old Aug 23, 2013 | 08:44 PM
mtnsammy's Avatar
mtnsammy
I found it very hard to see wear on ball joints with my truck. At the alignment shop he used a jack and 6 ft prybar. We saw some movement then but decided another day when money was better. No abnormal wear on new tires so I got lucky. Spring I will swap out all my joints and bushings. Winter the truck only goes a mile each day with the snow. I should be ok.
On your truck toe and shocks could cause cupping. The fact it is only in the center is too much air pressure. Gage the tread and see if it is wearing more in the middle. Every 5-7000 miles I check my tread wear. I get close to max mileage on all my tires doing this.
Old Aug 23, 2013 | 09:49 PM
EXv10's Avatar
EXv10
It doesn't call for 80, that is the highest pressure you can safely run with them and it is also where they are at their strongest. I run 60 also and it is not considered too high for the truck but it is the max most people run. I would cut back to 50 and try that.
tom18287
6.7L Power Stroke Diesel
22
Jul 17, 2015 10:47 PM
mrshark
2004 - 2008 F150
Dec 14, 2008 05:55 PM
haulingboat
Apr 14, 2008 07:14 PM
jdadamsjr
Aug 19, 2007 02:21 PM
Ed G
1983 - 2012 Ranger & B-Series
21
Sep 8, 2005 07:51 PM
