2008+ mirror conversion - who's done it?
Old Aug 30, 2013 | 08:01 AM
MoyockPowerstroke's Avatar
MoyockPowerstroke
Originally Posted by olemoffat
I just checked out the 1A site. Does a guy have to get the upgrade style for the early trucks or are the 08 up mirrors plug and play? I have a KR so I would like power, heated, clearance and signal lights, in chrome if possible. Just not sure on the fitment??
The design and features are all the same as the '08 mirror...you just need to let them know which MY you have so you get the right connector and support base. They will be Plug-n-play....the '07MY is the same as my '05MY...I just went with ChromeFactoryOutlet (NC), made them a Best Offer of $350. Comes with three different top covers a.) Chrome, b). Paintable, and c). Textured. That's funny...I just opened the link below to the seller I purchased my mirror set from and they are using a picture of my truck I sent them after the install. Pretty cool.
http://www.ebay.com/itm/2003-2007-Ford-Superduty-Towing-Electric-Mirrors-New-Both-sides-/181172537486?pt=Motors_Car_Truck_Parts_Accessories&hash=item2a2eb9888e#ht_1071wt_1234
Old Aug 30, 2013 | 02:19 PM
olemoffat's Avatar
olemoffat
Thanks for the link, those are exactly what I want!
Old Aug 30, 2013 | 09:39 PM
87crewdually's Avatar
87crewdually
Are both mirrors, upper/lower, heated?
Old Aug 30, 2013 | 09:52 PM
MoyockPowerstroke
Upper mirror is powered and heated....lower mirror can be manually adjusted only and is not heated.
Old Aug 31, 2013 | 08:58 AM
the_auto_tech's Avatar
the_auto_tech
I made an offer of 350 dollars on the ChromeFactoryOutlet mirrors as well and got them. I bought the mirrors from that link. Looking forward to getting them!
Old Aug 31, 2013 | 09:57 AM
MoyockPowerstroke
You will be please with them.
Old Aug 31, 2013 | 10:08 AM
the_auto_tech
I have a feeling I will be. Just seen another 6.0 yesterday that had those mirrors on it. They look so much better than the egg-shaped mrirors.
Old Aug 31, 2013 | 10:41 AM
olemoffat's Avatar
olemoffat
Do those mirrors have marker lights as well as turn signals, almost ready to pull the trigger!
Old Aug 31, 2013 | 11:58 AM
Curt's05's Avatar
Curt's05
Wiser by FTE
Originally Posted by npccpartsman
That looks like a lot of fun Curt. Do you have a detailed writeup of the project with wiring instructions??? Wow......
Nice job, BTW.
Thanks, i had about 15 hrs into wiring the 4 relays/installing the mirrors. Check my album for more info, i didn't post
the relay wiring(2008)
Old Aug 31, 2013 | 01:51 PM
the_auto_tech
Yes they do. These are the power/heated/signalling mirrors.
Old Aug 31, 2013 | 04:28 PM
olemoffat's Avatar
olemoffat
Ordered a set as well, can't wait!
Old Aug 31, 2013 | 08:32 PM
MoyockPowerstroke
Yep...marker lights. They even flash when you hit your truck lock/unlock on your key fob.
Old Sep 13, 2013 | 10:57 PM
  #28
olemoffat's Avatar
olemoffat
Thanks very much to the link for the ebay mirrors! I bolted them on in about 40 minutes flat and they work perfectly, no vibration at all! I would highly reccomend this upgrade to anyone!!
Old Sep 14, 2013 | 12:00 AM
  #29
kawika904's Avatar
kawika904
Right on bruddah! Glad it worked for you and thanks for updating us. The new and improved view is amazing isn't it.
Old Sep 14, 2013 | 06:53 AM
  #30
run6.0run's Avatar
run6.0run
Are you sure your lower is not heated?? I got a set of LKQ ones and they both are heated.
b.leevr
Aug 9, 2019 12:58 PM
jamestokelly
Nov 15, 2017 12:44 PM
pop639
Dec 8, 2016 12:48 PM
Byron W
2009 - 2014 F150
May 10, 2012 08:43 PM
doc76016
1978 - 1996 Big Bronco
Sep 29, 2004 11:01 AM
