No power, shutterring sometimes?
Old Aug 24, 2013 | 08:12 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Originally Posted by BLADE35
So are you saying to Basicaly hook a mechanical Fuel Press Gauge UP and Leave it Hooked up in the Engine??
It would work, but really would only be usefull for idle pressures, uses you propped it up in the cowl for a test run.
Josh
Old Aug 25, 2013 | 08:13 PM
kidoo's Avatar
kidoo
Thanks, I just saw the plug. I will get to that once I am back home. Truck runs good for now.
Old Aug 25, 2013 | 11:07 PM
BLADE35's Avatar
BLADE35
Josh
That sounds Good
Need a Hose or Line for it and Might be a Good Idea to Put a AIr Bleed Past the Gauge
Where we Getting the Hose or Line 3-4 feet of it don't ya Think
This was 60 bucks is it a POS link below
Black 7 100 PSI Fuel Pressure Gauge W Pressure Sender | eBay
I read about the electrical senders going out in these fuel gauges from time to time
Old Aug 25, 2013 | 11:24 PM
Bullitt390's Avatar
Bullitt390
That sounds Good
Visit a local hydraulic shop, John Deere or CAT dealer or find a Parker store and purchase the required fitting, maybe 4 feet of line and a normal 0-100 guage.
Way cheaper and easier than online.
Josh
Old Aug 26, 2013 | 06:33 AM
bismic's Avatar
bismic
That sounds Good
Here is a good thread to look over
Installed Fuel Pressure gauge - Ford Powerstroke Diesel Forum
A gauge isolator would be a good thing to consider if you plan on installing a mechanical gauge (although they are expensive and not as much of a safety issue w/ diesel).
http://www.dieselmanor.com/docs/dmi/...ions_rev43.pdf
Electronic gauges are much better IMO, but pretty high dollar.
Some accessories that might be needed:
<TABLE style="WIDTH: 593pt; BORDER-COLLAPSE: collapse" border=0 cellSpacing=0 cellPadding=0 width=791 x:str><COLGROUP><COL style="WIDTH: 593pt; mso-width-source: userset; mso-width-alt: 28131" width=791><TBODY><TR style="HEIGHT: 28.2pt" height=38><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: transparent; WIDTH: 593pt; HEIGHT: 28.2pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl24 height=38 width=791>Fuel Pressure adapter and hose (for remote location of the sending unit (install lower than the fuel filter bowl test port that it connects to). M12x1.5 to 1/8" NPT fitting:</TD></TR><TR style="HEIGHT: 13.8pt" height=18><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: transparent; WIDTH: 593pt; HEIGHT: 13.8pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl25 height=18 width=791>http://shop.strictlydiesel.com/store.php/products/60L_FP_Adapter</TD></TR><TR style="HEIGHT: 13.8pt" height=18><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: transparent; WIDTH: 593pt; HEIGHT: 13.8pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl26 height=18 width=791>http://www.puredieselpower.com/catal...ng-p-9494.html</TD></TR></TBODY></TABLE>
Old Aug 26, 2013 | 10:37 AM
BLADE35's Avatar
BLADE35
<table width="791" style="width: 593pt; border-collapse: collapse;" border="0" cellspacing="0" cellpadding="0" x:str=""><colgroup><col width="791" style="width: 593pt; mso-width-source: userset; mso-width-alt: 28131;"><tbody><tr height="38" style="height: 28.2pt;"><td width="791" height="38" class="xl24" style="border: rgb(212, 208, 200); width: 593pt; height: 28.2pt; background-color: transparent;">Fuel Pressure adapter and hose (for remote location of the sending unit (install lower than the fuel filter bowl test port that it connects to). M12x1.5 to 1/8" NPT fitting:</td></tr><tr height="18" style="height: 13.8pt;"><td width="791" height="18" class="xl25" style="border: rgb(212, 208, 200); width: 593pt; height: 13.8pt; background-color: transparent;">http://shop.strictlydiesel.com/store.php/products/60L_FP_Adapter</td></tr><tr height="18" style="height: 13.8pt;"><td width="791" height="18" class="xl26" style="border: rgb(212, 208, 200); width: 593pt; height: 13.8pt; background-color: transparent;">Ford 6.0L Powerstroke Fuel Pressure Gauge Adapter Fitting</td></tr></tbody></table>
Thanks Mark Looks Like I got some reading to do
Ford.Dude
Jun 8, 2019 09:49 AM
hndacr
Aug 10, 2011 08:51 AM
Chuckthetruck
6.4L Power Stroke Diesel
Dec 3, 2010 05:50 PM
YellerMax
29
Dec 28, 2009 08:01 AM
biggietx
Apr 17, 2008 11:23 AM
