c6
Old Aug 22, 2013 | 09:15 AM
jack odom's Avatar
jack odom
c6
Does anyone know how I can find which vehicles used a c6 transmission(small block)with a console shift. It would help with my junk yard
search for a transmission and other parts if knew witch vehicle to look
fo
Old Aug 22, 2013 | 10:27 AM
85e150's Avatar
85e150
Greetings and welcome to FTE.
What are you trying to do, and into what vehicle?
A SB C6 in a console car.....or truck?
Mustang/Cougar/Fairlane/Torino with the SB mostly used the C4 and FMX.
Bigger cars used the C6 with a console but with one or the other flaver of BBF.
Are you after the console, the shifter, the trans?
Here are some previous discussions that might could offer some light:
https://www.ford-trucks.com/forums/1...r-shifter.html
https://www.ford-trucks.com/forums/1...oor-shift.html
Old Aug 22, 2013 | 12:15 PM
Conanski's Avatar
Conanski
I believe you would find a C6 and a console shifter in some early '80's T-bird/Cougars and maybe Mustangs, and the C6 itself in Crown Vics and Lincolns but those were all column shift if I recall correctly. In the mid to late '80s the AOD started to appear so you would have to pretty much rule out everything from then on except 351/5.8 powered trucks.. which would get you the best built C6 for sure.
elemint
Oct 8, 2004 06:34 AM
Dalamatition
Aug 1, 2004 01:56 AM
MKPJ1
Jul 1, 2002 08:07 PM
