EFI to Carb?
Old Aug 17, 2013 | 01:39 PM
Hotroddaddy62's Avatar
Hotroddaddy62
EFI to Carb?
I have a 91 F150 4x4 with a 5.8 EFI. I want to get rid of the EFI, Computer,
smog junk, and cat conv! I want to go with a Torker intake, headers, stainless exhaust, etc. As of the first of the year the truck will be 25 years
old and I can register it for classic car/truck plates which in Texas means no state inspection!
Any ideas? KJ
Old Aug 17, 2013 | 04:19 PM
Conanski's Avatar
Conanski
I assume you meant 5.8 because there was no 3.8 in a truck.
What trans does it have? If it's the auto you're up against it because it is controlled by the same computer the engine is and it won't work at all without the computer and several powertrain sensors including the throttle position sensor and vehicle speed sensor. If it's got a manual then have at it but don't expect to see any power gains.
Old Aug 17, 2013 | 05:32 PM
Hotroddaddy62
Afternoon, Paul!
Sorry, Typo! I want to get rid of everything dealing with the EFI and computer!
I have a new 22 circuit wiring harness I was going to use and re-wire the truck
with out all the sensors! KJ
Old Aug 17, 2013 | 05:34 PM
Jarryd's Avatar
Jarryd
I've read numerous times that it's cheaper to just keep it efi. I asked before because it makes more swaps possible.
Old Aug 17, 2013 | 05:43 PM
tschrubb's Avatar
tschrubb
Outside of the novelty of putting a carb in with your own hands I think it warrants asking why you want to switch. As Conanski said (and he should be taken seriously) you won't really get any power gains and you'll loose a lot of convenience and precision (think about choking the motor on a cold day- no thank you). I'm guessing that you have an manual tranny as well since (again Conanski) an auto tranny needs the inputs and information about the engine to figure out which gear to be in...
Old Aug 17, 2013 | 07:30 PM
blkF250HD's Avatar
blkF250HD
Sounds like a bit of time and money to take a step backwards technology-wise. You can still ditch the cat and AIR system to clean things up if you'd like, the EFI will work fine without those. (just keep the solenoids plugged in)
Old Aug 17, 2013 | 07:53 PM
GNR22's Avatar
GNR22
Unless you fried the computer in your truck and already have the parts and time to put it together, there is no reason to put on a carb. You will be spending money on parts and lose power and fuel economy as well as reliability.
Old Aug 18, 2013 | 08:29 AM
Nothing Special's Avatar
Nothing Special
Sure, it's a step backward in power, economy and reliability. But face it, if we were all interested in maximizing power, economy and reliability we'd be driving Super Duties with Triton engines. But we're all on this forum, meaning we're willing to sacrifice some of that for some reason or another (have you noticed that '87-'96 F-series are gouped under "older, classic & antique trucks"?). If your reason is cost, it's probably cheaper to stick with the computer. But look at tonkymans thread on running better with SPOUT connector removed. The best analysis seems to be a bad computer. And the recommended fix? Go to a junk yard and get a computer that's not quite that bad yet. Not bad advice, and it'll result in the most power, economy and possibly reliability for the lowest cost. But I sure see the draw to going to technology that isn't likely to completely strand you, even if it's not quite as good 99% of the time
motorhead570
Jan 2, 2012 09:02 PM
TWULFF44
Nov 8, 2006 06:26 PM
Johnny0
Oct 17, 2005 09:58 AM
f-150rebel547
Jul 23, 2003 11:06 PM
Black_Bronco
1978 - 1996 Big Bronco
Feb 5, 2002 12:03 PM
