1978 - 1996 Big Bronco
Eo4D
Old Feb 3, 2002 | 10:28 PM
Black_Bronco's Avatar
Black_Bronco
Eo4D
can you make the E04D work if you make changes to the motor?
I want to remove the computer fuel and run a manifold carb setup,
long tube headers also.
Old Feb 4, 2002 | 07:54 PM
92bronco's Avatar
92bronco
Eo4D
why do you want to remove the efi ??? most 4x4 people with old rigs would kill for the efi -
EFI good things - works at angles - compensates for altitude changes -
carb good things ...... well I am still tring to think of some
good luck
Old Feb 4, 2002 | 11:51 PM
Black_Bronco
Eo4D
thanks
Old Feb 5, 2002 | 09:24 AM
sideout2's Avatar
sideout2
Eo4D
You will not be able to use the E40D if you remove the computer. All of the tranny functions are controlled by the computer and input from the engine. Carbs are easy and reliable and EFI can be intimidating, but with a little bit of research EFI is fairly easy to troubleshoot. Post your issue and I will see if I can help.
Old Feb 5, 2002 | 12:03 PM
8996EBBroncos's Avatar
8996EBBroncos
Eo4D
dieseltodd
6.2L V8
Oct 18, 2013 02:50 AM
IDMooseMan
Dec 8, 2008 01:31 PM
51dueller
20
Apr 5, 2007 06:45 PM
Titantis
Apr 1, 2006 10:41 AM
Black_Bronco
Feb 4, 2002 07:34 AM
