steering problems
Old Jun 14, 2003 | 08:01 AM
73tank's Avatar
73tank
steering problems
Hey all, My 73 f250 is manual steering, and this baby is loose, really loose. My distant cousin actually pulled me over the other day for suspection of D.U.I. not realizing it was me. Everything in the linkage seems tight. the only place I can feel the play is in the gearbox. Ican turn the steeringwheel side about 1/3 to1/2 a revolution before getting any movement out of the pitman arm. What is the best way to check / fix this .
I hit enough stuff already, I don't need any help.
Old Jun 15, 2003 | 01:05 AM
Torque1st's Avatar
Torque1st
Posting Legend
steering problems
Replace the box. Check your steering column rag joint also.
Old Jun 15, 2003 | 09:27 AM
73tank's Avatar
73tank
steering problems
Can I just replace the gears?, or am I just better off replacing the whole box?
Old Sep 19, 2003 | 09:11 PM
Psycho-Bob's Avatar
Psycho-Bob
steering problems
You're better off changing the box. You'd have to pull it off to change the gears anyway, and it's only three bolts to remove it. The cost also would not be different enough to warrant taking the whole thing apart. Mine went bad too, and I just changed the whole thing. Took about a half hour. But like the other guy said, check the rag joint, too. Good luck with it!
Old Sep 20, 2003 | 04:38 AM
John Pen's Avatar
John Pen
steering problems
What was the cost of the new box..? Was it from the boneyard or parts store ?
thanks..
Old Sep 21, 2003 | 09:37 PM
Psycho-Bob's Avatar
Psycho-Bob
steering problems
Actually, I had a parts truck and used the box from it. But I priced them from parts stores...$300!!! Are they nuts or what??? I would guess you could get one from a boneyard for around $75. Of course, one thing that is always good is to look around for another similar truck that has a broken frame or rotted body and try to pick it up cheap. That way, you can pull off everything that will fit your truck and store it away. That's what I did. I got some grease and brushed it on everything I saved, then wrapped it all in plastic and put it away. I still have stuff left over!
Old Sep 23, 2003 | 08:10 AM
73tank's Avatar
73tank
steering problems
$300? Crap, thats no good. A gear rebuild kit is not much less than that? Looks like its sloppy steering for a while longer.
Thank you ford.
Old Sep 23, 2003 | 09:03 AM
beartracks's Avatar
beartracks
steering problems
Well check the rag joints for sure on top of the box. I would think you could get one for more like $200 but haven't priced them lately.
Sickler1
Aug 14, 2011 12:36 PM
Explorer Freak
May 24, 2010 10:19 PM
Mustangfreak
May 13, 2009 08:01 AM
mooncricket1
Sep 14, 2006 08:47 PM
zuggetsr
1978 - 1996 Big Bronco
Mar 28, 2002 11:15 PM
