loose steering help
Old Sep 14, 2006 | 11:40 AM
mooncricket1's Avatar
mooncricket1
loose steering help
my 88 f-350 has very loose steering like 4-5 inchs either way on the steering wheel need help
Old Sep 14, 2006 | 12:59 PM
lenny1carl's Avatar
lenny1carl
could be several things or just 1. get under and chk tie rod ends, drag link, pitman arm, anything under, but i have a similar issue in my '91, and after ruling all else out for saftey sake, i know my problem is the steering box going to crap. i've adjusted 1 time and was good for 6 months, but i'm noticing it slopping up again. good hunting.
Old Sep 14, 2006 | 01:09 PM
mooncricket1
is adjusting the steering box easy or should i take it in
Old Sep 14, 2006 | 01:33 PM
lenny1carl's Avatar
lenny1carl
fairly easy, just a locking nut and a screw in-out adustment(sector shaft adjuster). but i beg you chk the steering components befor going to the box.
Old Sep 14, 2006 | 08:47 PM
doolsporter's Avatar
doolsporter
I fixed my 89 today
My F-250 had a lot of free play. At only 70K original miles all of the rest of the steering stuff checked out OK so I carefully adjusted the screw in 3/4 turn. It just seemed to be the right amount-I just left a little play in the wheel with the motor off and the wheels pointed straight. It was a huge improvement. That being said, I understand monkeying with it can lead to trouble. Time will tell.
btm991
Jul 19, 2016 11:27 PM
iravogel
Mar 24, 2016 06:25 PM
ebbtide
15
Sep 12, 2010 11:42 PM
chrissmallwood
May 30, 2010 02:16 PM
Jager
Apr 23, 2010 09:44 AM
