Sponsored by: Real Truck
Loose Steering?
Old Aug 13, 2011 | 12:04 PM
Sickler1's Avatar
Sickler1
Loose Steering?
i have an 2003 f250 and when iam driving down the road i have to move the steering wheel left and right to stay straight..feels like the steering is loose...any opinions?
Old Aug 13, 2011 | 12:58 PM
Special Ed's Avatar
Special Ed
Check all steering components & steering box for wear & slop.
Old Aug 13, 2011 | 02:02 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
Ball joints
If you have the factory steering stabilizer, consider replacing it, or adding dual stabilizers
I just installed a Fabtech Dual setup on my truck. It went from loose and wandering to tight and feels like a new truck. My balljoints were fine, but my factory stabilizer had died from the 35" tires
Old Aug 13, 2011 | 07:27 PM
Sickler1's Avatar
Sickler1
Will replace the the steering stabilizer n let u no how that worked out...how do I tell if the ball joints are bad
Old Aug 14, 2011 | 01:18 AM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
jack up the front end so the tires aren't touching. make sure to use jackstands and have everything secure for the next steps
grab the tire and try to get it to wiggle. don't be afraid to jerk on it
take a long stick and pry up under the tire. check for slack/movement from the joints
have a buddy/wife/gf turn the steering wheel while you are watching (truck on the ground btw). you want to see little or no slop in the linkage before the tire moves. A worn joint will have visible slop...and then the tire will move. That little bit of movement is what causes the wandering and vague steering sensation.
Old Aug 14, 2011 | 07:37 AM
Sickler1's Avatar
Sickler1
Your the man....will try this trick
Old Aug 14, 2011 | 09:01 AM
03F350XLT's Avatar
03F350XLT
03 f350 same issues. My steering box I thought but no. I foundvthat the box was not where the play was. My ball joints r a ok also. The slop was coming from my drag link. The end connecting to passenger side tie rod. The end St the pitman arm has no play but it does have a busted boot. I went ahead and ordered both ends and a adjustment sleeve. Hoping after I do the install no more play and no more wondering at highway speeds.
Old Aug 14, 2011 | 12:36 PM
AMG-SM's Avatar
AMG-SM
See if this helps you out:
https://www.ford-trucks.com/forums/1...-problems.html
springdale6
Apr 1, 2018 09:26 PM
Amicus
Jan 4, 2017 03:46 PM
f350rebel
Feb 28, 2008 10:38 PM
Alaska Tony
Nov 29, 2007 07:22 PM
