Sluggish Starting
Old Aug 11, 2013 | 07:59 PM
gtadim's Avatar
gtadim
Sluggish Starting
Hey everyone, I noticed my 2000 PSD EX is starting sluggish the last couple of days. Last time it sounded like this one of the batteries was no good, replaced it and everything was fine. that was a couple of years ago. So when I noticed it doing the same, i tested both batteries with a cca tester and the one I replaced 2 yrs ago was good, now it was the other one, so i bought a new battery today cleaned the K&N air filter and it still starts sluggish. The alternator and the starter have been replaced within the last year and half.
Any suggestions?
George
Old Aug 11, 2013 | 08:02 PM
Stewart_H's Avatar
Stewart_H
Could be a few different problems.
First thing you need to be made aware of though is, if money allows, always replace both batteries on a diesel, if one is bad.
Second thing is to get rid of that K&N filter and replace it with a filter that won't ruin your engine.
Third thing, I'm moving this thread over to the 7.3L PSD forum!
Stewart
Old Aug 11, 2013 | 11:06 PM
Pikachu's Avatar
Pikachu
It could also be the starter itself.
Old Aug 12, 2013 | 07:57 AM
Automator's Avatar
Automator
I'm having the same problem. Replaced both batteries and had the starter tested at Auto Zone. I did just get the truck back from having the transmission rebuilt.
Old Aug 12, 2013 | 07:27 PM
adam10's Avatar
adam10
just went thru this last week and so far so good.check amp output of alternater running on truck.my batteries tested good.and advanced said alt was good but running on truck was only putting out 50 amps.new alt and now it was putting out what it should.
Old Aug 12, 2013 | 08:36 PM
gtadim's Avatar
gtadim
Well guys, after checking everything out, it turned out to be the starter again. Good thing NAPA has a lifetime warrenty.(LOL) Is it just my truck or do other 7.3l eat up starters? This is the third one in 5.5 yrs.
Old Aug 12, 2013 | 08:43 PM
crop harvester's Avatar
crop harvester
what Ive learned here is, if you want to get out of the vicious cycle of replacing batteries ,starters,alternators. replace batteries in pairs & making sure your alternator is in good condition.replace starters & alternators with OEM units or better yet have a reputable shop rebuild for you.
Old Aug 12, 2013 | 09:33 PM
Pikachu's Avatar
Pikachu
I'm on my fourth (lifetime warranty) starter in 6 years. Next time it will go to a rebuilder instead of back to Pep Boys for yet another exchange.
Old Aug 12, 2013 | 10:06 PM
crop harvester
Im experimenting with a Denso 2.5kw 028000 series [ not China reproduction ] gear reduction starter that my electrical Rebuilder talked me into.was not cheap,to early to brag on with only one years time.
Old Aug 12, 2013 | 10:24 PM
Crewcab Turbo's Avatar
Crewcab Turbo
If you replace one battery at a time you will chase the problem forever. Batteries MUST be replaced in pairs. Not just in our trucks, anything with more than one battery.
Resendiz
Oct 18, 2016 03:15 PM
kla94
20
Jun 21, 2014 10:54 AM
chicagodragon
May 25, 2010 07:02 AM
Bird Hunter
15
Dec 5, 2009 08:29 PM
eyyu
Feb 22, 2005 10:36 AM
