Its a 95 F150. Im building it to be a sleeper so I dont really want big flashy aftermarket wheels but the tires I want only come in 16"+. I did a little searching but couldn't find anything definitive.
Are there any good looking Ford OEM 16"/17" alloys with a 5x139.7 bolt pattern? Or am I just gonna to go aftermarket?
I was going to go 16's also but bought a full set of crager soft 8's still in the boxes off of craigs list for $150. It was too good to pass up. I'd check Craigs list and see what pops.
Did you try TireRack.com? Put in all the vehicle info and the size you're looking for, and it will show you all the different styles.
I've looked at tirerack yes. Thats where i buy tires. I just wanted to know if there were any Ford OE 16"/17" wheels that would work before I buy a set of aftermarket wheels.
The wheels from newer F150s have positive offset while our trucks use neutral or negative offset to clear the trailing arms, so when fitting larger tires and rims you need to maintain that same backspacing or the tires will rub. Rims from newer trucks may bolt on but they will look a bit goofy tucked way in under the fenders and the tires may rub unless wheel spacers are added.
