View Poll Results: black or gray icm
black
0%
gray
100.00%
Voters: 2. You may not vote on this poll
black or gray
Old Aug 10, 2013 | 10:26 AM
grldben's Avatar
grldben
black or gray
hey guys i have a question i have a 1991 f-150 4.9l would like to know which icm i should use black computer controlled or gray push start kinda cofused thanks in advance
Old Aug 10, 2013 | 03:58 PM
rla2005's Avatar
rla2005
No reason for a poll. A quick search on this forum will tell you that you need a gray colored push-start style ICM. Ford did not start using the black ICM/CCD style ignition until 1994.
Many part manuals, including Ford are wrong....you need a gray colored Push-Start ICM. No ifs, ands or buts.
Old Aug 10, 2013 | 05:37 PM
Eddiec1564's Avatar
Eddiec1564
The black ICM(TFI module) will run with a older ECU but will not work properly as the black TFI does not control the dwell to the coil, it expects the ECU to do that. You will get hard starting ,engine pinging and misfires with the black TFI module.
Old Aug 11, 2013 | 07:01 AM
grldben's Avatar
grldben
Ok great thanks guys. Now to find the root of my problem
icrman
16
Jun 12, 2022 07:56 PM
jgrohs54
Jan 21, 2016 10:43 AM
perryau1996
Oct 3, 2011 11:33 AM
tygarcia
1978 - 1996 Big Bronco
19
Jan 29, 2010 08:00 PM
