4R100 Excursion Issue
Old Aug 13, 2013 | 11:50 AM
xplodn's Avatar
xplodn
A buddy is bringing over his laptop and OBD connector so I can troubleshoot it more and find out whats doing it. Also my coworker is going to follow me and check the brake lights after work.
Should I be looking for a sensor that reacts in an odd way right before the unlock? Log it all and go from there? I hate to be a newb but I havent ever needed to pull more than a code but am typically very capable of just about anything thats wrong.
Old Aug 13, 2013 | 01:41 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
You probably will need to log data to see what's going on. I suspect one of the sensors is sending data that is causing the unlock.
Old Aug 13, 2013 | 10:32 PM
xplodn's Avatar
xplodn
I am not declaring it fixed... but I replaced the TPS and its acting better. More testing tomorrow
Old Aug 14, 2013 | 08:03 AM
xplodn's Avatar
xplodn
Well.... Premature evaluation. TPS almost seems to have made it worse. Going to run with a friends laptop and software tomorrow and log it all in hopes to find it.
Old Aug 15, 2013 | 02:17 PM
xplodn's Avatar
xplodn
I have the scanner running and I am going to go over across the valley today after work and should have some good data about what is occuring before/during this problem.
Old Aug 15, 2013 | 07:01 PM
xplodn's Avatar
xplodn
Well Mark, I have about 1.5 hours of recorded data from today, did it on and off during the same situation... but I dont see anything jumping out at me on the log. Only thing I se reacting at the time of the RM change is the bank 1 Sensor 2 O2 Sensor goes from ~ 0.8 forever to ~ 0.2 for about 50 seconds then climbs back up there...
Do you have a way to read the log?
Old Aug 15, 2013 | 09:07 PM
Mark Kovalsky
I probably can.
Old Aug 15, 2013 | 09:24 PM
xplodn's Avatar
xplodn
Mark, The email got kicked back, so I replied to the message you sent
Old Aug 16, 2013 | 09:12 AM
Mark Kovalsky
I didn't get the message.
Old Aug 16, 2013 | 09:28 AM
xplodn's Avatar
xplodn
I sent it to the email you said and the one you sent it from... fastnewscustomers.com kicked it back though
Old Aug 16, 2013 | 09:49 PM
xplodn's Avatar
xplodn
Did it make it through to you Mark?
Old Aug 17, 2013 | 08:47 AM
Mark Kovalsky
No. It is fastnewcustomers.com. You have one too many "s" in there.
Old Aug 17, 2013 | 10:44 AM
  #28
xplodn's Avatar
xplodn
Sent again!
Old Aug 20, 2013 | 09:39 AM
  #29
xplodn's Avatar
xplodn
I towed my trailer in to work today to do a dry run. Towed fantastic and the problem was not around while towing.....who knows.
Friendly02
28
Apr 9, 2018 05:26 AM
Jacobsele
Apr 12, 2017 08:39 PM
Todd1577
Dec 8, 2015 04:41 PM
rch10007
Oct 21, 2013 09:11 PM
musstag
Jul 29, 2010 02:51 PM
