Storage capacity
Old Aug 6, 2013 | 09:47 PM
opkomdalen's Avatar
opkomdalen
That is a great idea and fits well.
Doug
Old Aug 6, 2013 | 09:51 PM
Harrier's Avatar
Harrier
Originally Posted by ALBUQ F-1
He did that on BOTH sides! He was trying to fit a spare mount on the outside of the bed... Duh... if it won't fit on one side, it ain't going to fit on the other.
I guess he never hear of a tape measure either. Well if it wasn't for you guys, I would probably be one of those PO's., but dang!
These are both relatively easy to remove. I do use the truck for hauling, my other truck has a shell on it and that limits some type of loads. The box in particular won't normally be there, but for trips, possible camping, even when I have something I don't want in the cab for security reasons, it will be useful. I hate parking with something in the bed when out shopping, for example.
Cool, on my daily driver I recently got a rollup tonneau cover. It's so nice to be able to have stuff in the bed and still out of sight. It also still has full bed access unlike those hard covers.
It sounds like you have a good plan for the use of it and still keep the (I think) cleaner look of the bed without a box for most of the time. Of course you and a good thought out plan seem to always be together.
Old Aug 6, 2013 | 09:55 PM
Jolly Roger Joe's Avatar
Jolly Roger Joe
That looks good Ross. And that's a great place for your spare.
Old Aug 6, 2013 | 10:04 PM
bobbytnm's Avatar
bobbytnm
Roast em' if you got 'em
Ross,
Just cut that spare in half. Then it will fit nicely inside the box
No need to thank me. Its all part of the service
Bobby
Old Aug 6, 2013 | 10:21 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Great idea Bobby... did you used to own my truck?!
I hate to admit it, but I was all set to mount the box up flush against the spare... then I realized I couldn't get the spare out without moving the box...
It would have saved almost a foot behind the box, tho.
Old Aug 7, 2013 | 04:00 PM
tinman52's Avatar
tinman52
Welder User
Originally Posted by Doc
Do you have a picture of your tonneu cover handy? I'd be interested in seeing it.
Here you go Doc.....
Old Aug 7, 2013 | 05:23 PM
bobbytnm's Avatar
bobbytnm
....if you think about it, a tire only goes flat on the bottom. So, theoretically all you really need is about 1/3 fo the spare....just enough to grab 2 studs and touch the ground. Talk about a space saver!
This will revolutionize the automobile industry...wooohoooo
Old Aug 7, 2013 | 06:50 PM
53OlderThanMe's Avatar
53OlderThanMe
Wish I had read this first. I just bought 2 new replacement wheels today. I could have bought 1 and had a 1/3 piece leftover for the spare.
Old Aug 7, 2013 | 07:54 PM
Doc's Avatar
Doc
Very nice! Thanks. Your property looks really nice in the background, as always with your pics.
Old Aug 23, 2013 | 08:34 PM
mytbtruck's Avatar
mytbtruck
Storage capacity is definitely a problem. No where to put anything when on a trip in a 1948 cab. I used a foot locker and mounted it on 3 inch aluminum strips. When I won't need it for traveling I can take it out and bed will be back to normal. The reason it is in the back is for easy access with a bad back it is hard to lean over the side to use it.
Old Aug 23, 2013 | 09:04 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Looks nice! Have you got a picture of the aluminum strips? I've been thinking of raising mine up so water can't pool under it.
Old Aug 24, 2013 | 01:43 PM
mytbtruck's Avatar
mytbtruck
It wasn't a simple plan. I had to replace the 5/16 bolts with 3/8 and machine the top flat, drill and tap them for 10-32 screws. Polished some 10-32 button heads to screw in when the foot locker is not in the truck. The strips are 1/2 inch thick and 3 inches wide. Drilled for a 10-32 socket head screw sunk below the surface. The foot locker sets on top of a 1/2 inch plywood bottom with 1/4 -20 button head screws holding it down. The inside is completely carpeted and the bottom has a 1/4 plywood removable bottom with carpet over it. Sounds like a lot of trouble but I like unique things. Some people may even think I am eccentric, but I am almost normal.
Old Aug 24, 2013 | 01:58 PM
  #28
ALBUQ F-1's Avatar
ALBUQ F-1
I've been thinking of putting plywood underneath, too. Also insulating the lid.
Old Aug 24, 2013 | 09:48 PM
  #29
mytbtruck's Avatar
mytbtruck
The top of this foot locker is double wall and has foamed insulation between it. I can actually sit on top of it and it will not bend at all. I am well pleased with my arrangement.
Speedee19
Aug 12, 2024 02:57 PM
52'F-3
16
Sep 15, 2018 06:02 PM
Vinford
13
Mar 26, 2011 11:16 PM
jmadsen
Aug 25, 2009 03:35 PM
Old Rust Bucket
General Automotive Discussion
Nov 12, 2007 09:56 PM
