Glow Shift Quad Pillar?
Old Aug 27, 2013 | 12:10 PM
99ExpyProblems's Avatar
99ExpyProblems
Originally Posted by dhag911
That would pretty cool to do you have pictures of them
1999-2007 Ford 4 Gauge Windshield Above Mirror Mount Autometer 18018
Old Aug 27, 2013 | 12:11 PM
acf6's Avatar
acf6
Only thing with those is the 4 gauge pod takes quite a bit to get it to stay up there...my friend has one and its always falling off
Old Aug 27, 2013 | 03:43 PM
BLADE35's Avatar
BLADE35
Don't Hack the Harness to splice in all those Gauges especialy for Ones that's Already can be Gotton threw the OBDII Port
You wont need to watch ECT and EOT Constantly Like that You will get a General Idea and Check them Occasionaly
Oil Cooler clogs Over Time you will see it coming
Cutting into the Harness and Adding all the Wire Ect will throw Readings More wire More resistence it Skews the reading some
If your going to put Senders the Location may decide How Accurite it Reads Anything With a Test PORT is GREAT USE That Spot
Fuel Press
LOW Press OIL
EGT*
That's My .02 You may not like it IDK
I like the 4 pod gauge by the Mirror But sounds like it will need a Little help with how it mounts
Old Aug 27, 2013 | 08:06 PM
jswartz84's Avatar
jswartz84
My gauges look just like this only black backgrounds. I have only held them in place to see what they look like so haven't taken pictures yet. They pod came with Velcro but I'm not so sure I will use it. Anybody have any suggestions as what to use?
Old Aug 27, 2013 | 08:32 PM
99ExpyProblems
I don't know what the top of that gauge pod looks like, but you could probably get some clips like they use on the back of tape measure to clip to your belt and screw them into it? I saw someone do something with the dollar store tape measures for the scangauge II to mount up there.
Also, the velcro they include with most anything these days is worthless. Go to Home Depot or Lowes or Wal-Mart and get the industrial strength stuff. I bet it holds. I would use double sided tape to keep the wires up on the roofline too.
Old Aug 27, 2013 | 08:35 PM
jswartz84's Avatar
jswartz84
It slips under the headliner and is suppose to Velcro to the windshield but I thought something else might be better then Velcro.
Old Aug 27, 2013 | 08:36 PM
acf6's Avatar
acf6
the stuff that came with my helmet cam would probably work, pretty sure its a 3M product. its like an ultra velcro, when i want to take my cam off my helmet with that stuff, i need a screwdriver to pry it off
Old Aug 27, 2013 | 08:38 PM
acf6's Avatar
acf6
Old Aug 27, 2013 | 08:39 PM
jswartz84's Avatar
jswartz84
No kidding. I forgot about the 3m Velcro for the gopro. Great suggestion.
Old Aug 28, 2013 | 12:57 AM
dhag911's Avatar
dhag911
looks good
Old Sep 9, 2013 | 08:09 AM
billyrb's Avatar
billyrb
I installed their 4-pod cluster and can confirm, they block use of the sun visor. If the pod could be made with the gauge openings rotated down to about the 6 o'clock position, it would be fine. The gauges are a little bright at night (even set at N1 with the lights on), but its not bad.
Old Oct 9, 2013 | 01:47 PM
99ExpyProblems
Thanks for the update. I still haven't ordered mine. I'm so indecisive. I can't believe you registered in 2009 and you only have two posts in 4 years! lol I repped you just for that!
twm011
20
Apr 29, 2015 01:51 PM
Brown Falcon
Aug 4, 2010 06:15 PM
jeffdoerr
23
Feb 16, 2009 08:01 AM
mikewrt
Sep 24, 2004 11:49 AM
Ford1TonsRock
May 11, 2004 07:42 AM
