1990 5speed issues
Old Aug 4, 2013 | 08:45 AM
topdawgtrkr's Avatar
topdawgtrkr
1990 5speed issues
hey...I have a 1990 f250...4.9...4x4...5speed...heres the problem i have 1st and reverse will go into those gears with the clutch in engine running..however will not engage into the others...with the engine off will go into all gears...truck will drive but wiil not progressively shift
Old Aug 4, 2013 | 02:05 PM
bashby's Avatar
bashby
Don't see too many 4.9 F250's, it should have the zf5 in it. Does the clutch seem to work ok?
Old Aug 4, 2013 | 02:10 PM
kevin206's Avatar
kevin206
My guess is worn out clutch or bad slave cylinder. Unfortunately, I think you may have to pull the tranny to access the slave cylinder on the 5 speeds. Or so I have been told.
Do you have plenty of fluid in the clutch resevoir?
Old Aug 5, 2013 | 09:31 AM
topdawgtrkr
5speed issuse
there is plenty of fluid, the truck will drive fine just the shifting is bad, no noise in neutral, and yes come to the conclusion about pulling the tranny to r/r slave cylinder and while im in there the clutch and pressure plate..and maybe the fly wheel too
Old Aug 5, 2013 | 07:36 PM
warren561's Avatar
warren561
IIRC, the ZF has the slave cylinder outside the bell housing. The Mazda M5R2 has the slave cylinder inside the bell housing.
So, check your transmission type, you may not need to drop the entire transmission.
I thought the Mazda wasn't offered on the F250's.
cj091184
1983 - 2012 Ranger & B-Series
Jan 3, 2007 01:43 AM
gergo
Sep 2, 2006 01:28 AM
1987fi50
Nov 22, 2005 02:19 PM
kozielj
Sep 8, 2005 12:36 PM
Talyn
Nov 22, 2003 03:43 PM
