I'm assuming you are referring to the parking brake light...Try WD-40 on the sensor mechanism, or replace the sensor (the button piece is most likely sticking when you apply the brake).
It must be the switch in the parking brake pedal. Now I have to locate it and try cleaning it first, and if that doesn't work then replacing it. I fiddle farted around with it this morning and if I play with engaging and releasing the pedal the light will occasionally come on. So, yea, process of elimination to the switch. Thanks for the quick replies and help guys.
