Brake Light stays on
Old May 16, 2003 | 01:25 AM
Racerdave's Avatar
Racerdave
umm.... My brake light just came on the other day and it wont go off.
1)What causes this?
2)where is the sensor that makes it turn on?
I know I probably need to bleed my brakes, since the last time I did it the fluid was really old and nasty, so I think I will flush them out one more time and then see if that helps. but if it doesn't why is the light on?
My parking brake used to be way too loose (didn't even stop me from rolling), so I went underneath and took a look and seen how to adjust it (had to soak it for 2 days) but finally got the nut loose and screwed it in a bit so it kept me from rolling, but now it must have got loose again because it doesn't do much anymore...?
Any ideas on why my parking brake does this and why my [size=]brake[/size] light is on?
And what usually causes it to go on?
Worn drums or pads?
Or maybe a fluid sensor?
Old May 16, 2003 | 02:53 AM
Torque1st's Avatar
Torque1st
Posting Legend
Dave-
There is a switch mounted above the brake pedal that activates the brake lights on the back of your vehicle. When the pedal comes up it opens the switch, otherwise it is closed and the brake lights go on.
There is also a brake fault indicator light in the dash that comes on if the proportioning valve shifts due to a brake failure.
Old May 16, 2003 | 05:22 AM
tack338's Avatar
tack338
Some master cylinders will cause the light to go on when they are bad also. Just one more dang thing to check!
Old May 16, 2003 | 07:48 AM
big1's Avatar
big1
Early model's didn't have the master cylinder sensor. The most common reason for the light to come on is an imbalance in the braking system ( I'm assuming you are talking about the "Brake" light in the dash?) You may want to check the rear brake shoe's. They may be severly worn. This can cause both of your problem's.
Old May 16, 2003 | 06:48 PM
76supercab2's Avatar
76supercab2
1. Stop driving the truck! Something is wrong.
2. Check the brake fluid level.
3. Does the pedal go down to the floor while applying the brakes at a stop? Bad Master cylinder.
As stated before the switch is mounted in between the front and back brakes at the proportioning block. If the front or back brakes fail and there is a difference in pressure between the two systems, the switch is forced off center and lights the light. Air in one system (front or back) could cause this. Both times I have seen it a bad master cylinder caused it.
AFTER THE BRAKES ARE REPAIRED, you can reset the switch by pressing down on the brake pedal as hard as you can. It will reset the swithc.
Old May 17, 2003 | 02:44 AM
Racerdave's Avatar
Racerdave
Ok I will take it in and have them looked at, thanks for the fast replys!
Old May 17, 2003 | 08:43 AM
jeffreysw's Avatar
jeffreysw
On my truck, the pedal wasn't returning quite far enough to make the switch (it's under the dash at the top of the pedal arm). I got a rubber tie-down strap and made a pedal return spring so the pedal returns all the way and it solved the problem. There's also some adjustment in the switch (it's treaded so you can move it in or out by rotating it).
Old May 18, 2003 | 02:20 AM
Racerdave's Avatar
Racerdave
ok it seems to me like everyone thought I was talking about my tail light brake light...... I was talking about the one in my dash not the one in the rear..... I just did some work to the truck and started her up today and the light didnt come on? So I hope it ws just some air in the line, but better safe then sory, takeing it in and hain them looked at on monday.
Old May 18, 2003 | 02:29 AM
Torque1st's Avatar
Torque1st
Posting Legend
Well you didn't specify so we had to make guesses. Normally the light in the dash is called the Brake WARNING Light, or the Brake Fault Indicator. So we had to address BOTH possibilities.
Old May 18, 2003 | 02:39 AM
Racerdave's Avatar
Racerdave
gochya !
Old May 18, 2003 | 09:10 AM
jeffreysw's Avatar
jeffreysw
There's a sensor on the proportioning valve (by the steering box) that senses the pressure in the brake system. I think this is the one that also lights the light on the dash. The proportioning valve sets the bias between the front & rear brakes. The light's on for a reason. At first I would assume the light's doing its job and check the brake system. If you've checked the brakes and can't find anything wrong, then it's time to find out why the light is on.
The Chilton's manual for the 73-79 F100 - F150 has very accurate wiring diagrams and is very useful for finding shorts and grounded wires. I used the schematics to find two wires that were pinched together under my truck that were keeping the rear brakes lights on continuously. I'd probably still be looking, but the wire colors in the Chilton's manual were accurate, so once I took the cover off of the bundle going back to the rear of the truck, it was pretty easy.
pbruckne
6.7L Power Stroke Diesel
17
Jan 5, 2020 07:45 AM
awq134
2009 - 2014 F150
Dec 25, 2014 01:50 PM
Grinder Man
Oct 10, 2014 09:35 AM
Ford Fx4
All Things Towing
Feb 24, 2008 08:03 PM
Dan F 2
1983 - 2012 Ranger & B-Series
May 30, 2006 02:05 PM
