Dash cluster voltage regulator
Old Aug 1, 2013 | 07:17 AM
664x4drvr's Avatar
664x4drvr
Morning guys, quick question. On my dash voltage regulator ,My test light burns constant on one post while being intermittent on the other post like a fast signal light. I assume it should be constant on both ? The only dash light I have is my green signal , which also blinks w / my signals .
Old Aug 1, 2013 | 07:41 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
B9MZ-10804-C .. ICVR - Instrument Cluster Voltage Regulator has nothing to do with the oil warning (idiot) light.
The warning light sending unit (B6AZ-9278 B - Motorcraft SW-667) is pressure activated. It's a notorious POS, as it gets gummed up with dirty oil, the light no longer works.
ICVR affects the fuel and temp gauges. When it begins to fail, the needles of these gauges do "the hula" .. swing wildly back/forth on their own. When the puppy fails, the needles peg at F & H
Old Aug 1, 2013 | 09:49 AM
daveengelson's Avatar
daveengelson
If understand correctly may be referring to the Constant Voltage Regulator (CVR) located on the back of the instrument cluster. The CRV receives constant voltage on 1 side and the other oscillates from between 0-9 volts, kinda like a shock absorber to the dash instruments.
http://i300.photobucket.com/albums/n...reDiagP5-1.jpg
Assuming you have the 'sweeping speedo' instrument cluster if I were to hazard a guess I would say the green blinking light is your rt/lf turn signal indicator light.
http://i300.photobucket.com/albums/n...s/IMG_0012.jpg
http://i300.photobucket.com/albums/n...tos/6c73_1.jpg
Believe the green light on the opposite size is for low/hi beam indicator.
Old Aug 1, 2013 | 07:29 PM
bunchoftrucks's Avatar
bunchoftrucks
If you do have the sweep style gauge cluster the only blinking green light will be the Blinker as stated by the previous post. I puzzled on that the first time I drove my 66. The ICVR does have constant voltage to one side and buffers it to the gauges. If the only lights that you have are the gauge illumination and they don't come on it's pretty easy to figure it out. Test with your meter, with the light switch on , is there voltage, if not you need a light switch, if there is you need light bulbs. Of course if the wiring harness has been tampered with you could be in for a bigger adventure.
Hope this helps.
Old Aug 2, 2013 | 01:47 AM
Scifi266's Avatar
Scifi266
Your turn signals run off the flasher so it blinks, the cvr is just a coiled wire around a little strip of middle to send out 6 volts to the gauges as they don't run off 12 volts. When mine burnt out I actually went and bought a solid state voltage regulator that works awesome, 5 bucks and 10 minutes to solder and install works like a dream.
Old Aug 2, 2013 | 08:12 PM
664x4drvr's Avatar
664x4drvr
Ok more background, cab off restoration, all new paint on everything , wiring was left intact. It is sweeping style , I'm having problems getting grounds. Asking to get understanding how a CVR works, have gotten most things working . Only white dash bulb I have is my green signal , so that's not right. it also blinks w signals. New headlight switch , new bulbs. so its probably a ground problem . no horn. Thanks for replying. I have color coded wiring diagram . I only checked it w test light.
Old Aug 2, 2013 | 09:13 PM
NumberDummy
Sweep speedo cluster: The amp (10850) and oil pressure (9273) gauges were standard equipment on Camper Specials, optional on others.
The instrument cluster bezel (C5TZ-10838-A) has been reproduced by Carpenter, but (like the genuine Ford original), does not come with holes punched out for these two gauges.
Old Aug 4, 2013 | 09:17 PM
664x4drvr's Avatar
664x4drvr
Update, I do not have the extra gauges, may add them later. I now have dash lights everything works except my alternator light burns with battery showing 14volts while engine is running.
Old Aug 6, 2013 | 02:58 PM
664x4drvr's Avatar
664x4drvr
[quote=664x4drvr;13404186]Update, I do not have the extra gauges, may add them later. I now have dash lights everything works . My alternator test showed a open diode, so I replaced the alternator. BUT.. alternator light is still burning when running. is there a connection I could check to turn the light off ??
leonharu
Feb 12, 2017 10:05 PM
Ole Green 1978
Feb 16, 2012 08:22 PM
tdwhiteIII
1966 - 1977 Early Broncos
Feb 21, 2006 10:10 PM
66f100352
May 26, 2004 10:02 PM
clean79150
Electrical Systems/Wiring
May 20, 2003 11:02 PM
