alt light
Old May 26, 2004 | 03:11 PM
66f100352's Avatar
66f100352
alt light
I have a 66 and have tried everything to get my alt light as bright as my oil light but it just isn't i've cleaned all grounds and charging system wires new reg new alt new bulb still not as bright better but not the same as the oil light. On a postive note the charging system is working excellant lol. My question is what's everyone elses like? Thanks
Mark
Old May 26, 2004 | 06:24 PM
barry's Avatar
barry
The lens on the dash cluster is probably opague with age or is very dirty. The light doesn't shine thru it as brightly as the oil light. You might try to take the cluster out and give it a good cleaning,
Barry
Old May 26, 2004 | 08:30 PM
66f100352's Avatar
66f100352
I take it yours is bright? The lens does look a little cloudy but even with the buld out it still looks dim. I tesed the socket and here's what I found if I test the postive center termail and hook up the voltmeter to a ground i get batt voltage but if i test it with the ground in the socket it's about 8 volts.grrr
Old May 26, 2004 | 10:02 PM
cdherman's Avatar
cdherman
Dielectric grease.
Slankky
Aug 19, 2012 02:02 PM
thebeast88
New Member Introductions
Jan 14, 2010 08:19 PM
Pocca
Electrical Systems/Wiring
Jul 25, 2007 01:31 PM
karljay
General Automotive Discussion
Feb 27, 2006 06:20 PM
Mikey Hot Dog
Aug 29, 2003 09:55 AM
