Instrument Voltage Regulator:
Old Feb 9, 2017 | 06:28 PM
leonharu's Avatar
leonharu
I was wondering if there is a way to check the instrument voltage regulator to see if it is broke.I removed the one on my 1973 F-100 today and have one on order from DC.My fuel and temp gauge have been reading erratic for a while.Hope this is the problem.I thought I could change it under the dash at the back of gauge cluster but ended up pulling the cluster out from up top!I had a bulb out for the heater control anyway.I also have a bulb out in the radio and it looks like a major job to change it????Has anyone been down this road lately?
Old Feb 9, 2017 | 11:31 PM
Fordworth's Avatar
Fordworth
You can check the IPVR when it's installed by putting a test light to the terminals. The input side should light the light constantly of course but the other side should cause the test light to flash at a regular rate. The flash rate is adjustable by turning the little deal on the back. I'm not sure on the proper interval, though.
Old Feb 10, 2017 | 01:18 AM
Ozzie H.'s Avatar
Ozzie H.
The '76 truck shop manual says that the IVR (instrument voltage regulator) should produce a pulsating voltage which averages 5.0 volts at the gauge terminals.
Old Feb 10, 2017 | 08:38 AM
bulldogcountry1's Avatar
bulldogcountry1
I had the same question. My gauges all work, but the bulbs flicker. I know some of them are just bad, but the ones that do work seem weak and erratic.
Old Feb 10, 2017 | 08:43 AM
Canus's Avatar
Canus
Bulldog, the gauges use the IVR but the lights use full 12 volts. If the lights are weak and erratic the IVR is not your problem.
Old Feb 10, 2017 | 10:09 AM
Ozzie H.'s Avatar
Ozzie H.
The light problem could be a "funky" switch or "bum" grounds.
Old Feb 10, 2017 | 11:52 AM
meangreen92's Avatar
meangreen92
And if the flickering is the fault of the switch, it doesn't mean you need to replace it.
How does the dimmer work? Does it smoothly dim the lights, or are there 'drop-outs' making the lights flicker during dimming (and brightening)?
If the switch seems bad, try spraying it with WD40. I've restored many a rotary potentiometer, and even a few positioned switches this way.
Old Feb 10, 2017 | 11:54 AM
78 PEB's Avatar
78 PEB
^^^^Or contact cleaner^^^^^
Old Feb 10, 2017 | 02:09 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
If the fuel and temp gauge needles do the "hula" .. swing back and forth on their own, or if the needles have pegged to the right, the ICVR (Instrument Cluster Voltage Regulator) is defective.
D1AZ-10804-A .. ICVR (Motorcraft GR-513) / Obsolete ~ Available NOS & from auto parts stores.
1971/86 F100/350 & Bronco; 1971/91 Econoline; 1983/85 Ranger; 1984/85 Bronco II // Misc: 1971/79 FoMoCo Passenger Cars.
Old Feb 10, 2017 | 02:22 PM
lasermike's Avatar
lasermike
The IVCR does produce about 5 volts. It uses a bimetallic strip and a set of contacts along with a heater.
Contacts closed = heater on. When temperature is high enough, contacts open. When it cools enough, contacts close. This provides a "stable" voltage for the gauges. On an oscilloscope, the "DC" looks horrendous but with an old analog voltmeter, it will be a fairly steady 5 volts.
If the dash lights flicker at a steady rate, and especially if they change with engine speed, you either have a slipping alternator belt, a very low idle, a bad diode or 2 or maybe a weak battery altho I would think that would show up in poor starting too.
Michael
PS, DeOxit is my favorite contact cleaner even though I call it snake oil due to it's claims but it really does work. I've brought many non working things back to life with it.
Old Feb 11, 2017 | 06:58 PM
bulldogcountry1
After some tinkering, I decided to clean the contacts on the circuit board and the bulb sockets. That stopped the flickering, but I was able to discover I had 3 bad bulb sockets.
I also discovered an issue with the turn signal switch. I have jiggle the lever a bit to get them both to work. Is that something that can be fixed?
I also found that all the lights were only getting 8.5v. Are they supposed to get 12v?
Old Feb 12, 2017 | 02:49 AM
Ozzie H.'s Avatar
Ozzie H.
It may be time for some new sockets.
Given enough time and money anything on a truck can be fixed.
If "all" means all the panel lights it likely is due to the dropping resistor in the light switch or a sad connection somewhere in that circuit. If "all" means all the lights on the truck it is a different matter.
A bit of clarification is needed.
Old Feb 12, 2017 | 08:32 AM
bulldogcountry1
Turn signal switch: I see that a new one can be had for about $60. I was just curious if the original was typically something that can be refurbished pretty easily.
Lights: I meant that all the lights on the instrument panel were reading 8.5v. I didn't check the headlights or any others. I'll check and see what the switch is putting out.
Old Feb 12, 2017 | 10:46 AM
Ozzie H.'s Avatar
Ozzie H.
You will likely have to further investigate the turn signal switch. If the intermittent connection is due to a "contact" connection shortfall, then perhaps a good cleaning and/or lubrication will help. But if it's due to wear on the switch then likely only a replacement switch will solve the problem.
Old Feb 12, 2017 | 10:05 PM
lasermike's Avatar
lasermike
The instrument panel lights should get a full 12 volts with the dimmer cranked all the way up. It sounds like the wiper may be dirty on the dimmer rheostat. It's the carbon looking thing that rubs on the turns of the rheostat when you turn it and is the thing that we are talking about cleaning when we mention using contact cleaner on the light switch. It also may be dirty where the rotating part make an electrical connection to the stationary part.
Michael
srfordf100
Mar 20, 2015 02:16 PM
664x4drvr
Aug 6, 2013 02:58 PM
johnhammond
Apr 18, 2012 06:43 PM
Truckboy
Nov 11, 2006 08:13 PM
mt_ford_300
Electrical Systems/Wiring
Jun 16, 2003 10:14 PM
