BW 13 56 transfer case problem
Old Aug 2, 2013 | 03:40 PM
brokeasajoke's Avatar
brokeasajoke
Since you have a little time a welding shop can fix the aluminum case where the oilpump finger goes if it has almost cut through the "bumps" for.lack of a better word that hold it in place. Mine needed repaired but i used it any way.
Old Aug 2, 2013 | 03:47 PM
daleyboy's Avatar
daleyboy
The guy at the transmission shop asked me about that too. There is absolutely no wear on those bumps on the case that the pump part is in
Old Aug 3, 2013 | 09:54 PM
tecgod13's Avatar
tecgod13
The other fix for the pump spinning is to weld a piece onto the pump arm to spread out where it touches on the case. I found that fix online somewhere and welded a piece of rod onto the end of the arm. Thats cheaper and easier than welding the case.
Johnwb150
2009 - 2014 F150
Dec 13, 2014 05:46 PM
trueman
Dec 5, 2011 03:07 PM
PauL3861
29
Mar 20, 2009 02:12 PM
dyhrdford
Feb 21, 2008 04:52 PM
scoutt
Sep 3, 2007 06:44 PM
