Dont laugh
Old Aug 1, 2013 | 04:16 PM
Misky6.0's Avatar
Misky6.0
Originally Posted by diesel_dan
So going some years back when we had a pool, the filter was a sta-rite stainless number with a cartridge in it. The housing split in the middle and had a clamp that held the 2 halves together and a large o-ring did the sealing. Second time I was having to replace the o-ring the pool parts store guy asks if I use "o-ring seal". That seal lasted 8 yrs, maybe even more as we moved -- the grease was the trick...
that stuff was just pure silcone grease, which most folks (other than us) use for things like spark plug boots (also known as di-electric grease).
I use the stuff on all o-rings and in particular ones having to do with water (like all the ones on my well filter system) -- no leaks and never stuck.
Has anyone tried this stuff on a coolant filter? I'm happy to be the first if not... filter system goes on next week (finally).
THANK YOU! I struggle each fall to winterize my barn (to prevent freeze damage) in Colorado 'cause removing the water filters on the treatment system is a PITA. I will try silicone grease on the O-rings next spring.
Old Aug 1, 2013 | 04:24 PM
bpounds's Avatar
bpounds
Here is a thread showing how I relocated the filter to make it easier to get out of there. Helps get the wrench on, and helps limit how much coolant spills all over.
https://www.ford-trucks.com/forums/1...nt-filter.html
bubba_78363
Jan 28, 2015 12:33 PM
TruckNorris
Jan 14, 2012 08:02 AM
olfordsnstone
Jul 9, 2011 11:22 AM
danocross
Jun 14, 2010 08:47 PM
jmaskew
Feb 15, 2008 06:09 PM
